Old 10-10-2015, 07:06 PM   #1
abomb's Avatar
Is this normal?
I am winterizing my camper. I pull out the heating element, and this is what it looks like. Is this normal? It's a 2015 Palimino Puma 295bhss. I bought it last August. I used it twice last year and all this summer. Hot water heater was used, but not alot. Mainly used on propane. Even when I don't heat the water I still circulate it everyday the camper is in use, so it doesn't sit. I can't see a heating element only lasting one year.
2015 Palimino Puma 295 BHSS
Anniversary Edition 5th Wheel
2006 Ford F250 Diesel
abomb is offline   Reply With Quote
Old 10-10-2015, 07:09 PM   #2
abomb's Avatar
And it was never turned on without water being in it. Thanks
Old 10-10-2015, 07:12 PM   #3
That looks like an anode rod and they only last about a year or two, cheap/easy to replace.
Amazon. Few weeks ago I checked and mine was eroded down to the center wire. Replaced and bought a spare.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 10-10-2015, 07:12 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
This is not the heating element it is the water Anode which takes out water impurities. They need replacing every so often. One should drain the Hot water heater when not in use to prolong the life of the element.
Yours looks like its time to replace. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 10-10-2015, 07:17 PM   #5
abomb's Avatar
Thanks, that makes sense....heating element would have wires attached. Could it be my water wearing it out faster? Or that's just normal wear. I only fill up at my house using well water.
Old 10-10-2015, 07:17 PM   #6
Is this normal?
You should be able to get another year or two out of that. When the whole rod looks like the part by the plug then you need to replace it. If you google anode rod you will get diagrams that show the ware rate and when you should replace it.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 10-10-2015, 07:17 PM   #7
Ford Idaho's Avatar
The sole purpose of an anode rod is to protect the water heater tank it does nothing to or for the water.
https://www.google.com/?gws_rd=ssl#q...+anode+rods+do
Old 10-10-2015, 07:20 PM   #8
It reacts to the mineral content in the water to save the lining of the steel water tank. Well water likely has a high mineral content. Try a few more months, and order replacement in the mean time.
Old 10-10-2015, 07:23 PM   #9
http://www.lets-getaway.com/images/AnodeRod.jpg. This is the diagram I have seen for ware
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 10-10-2015, 07:35 PM   #10
aceinspp's Avatar
Sorry but that is the purpose just like on boats. It takes out impurities. DA Later RJD
Days camped 2017 62
Days camped 2018 18
