Old 08-22-2015, 12:27 PM   #1
it's going to be 28 tonight - do i need to worry?
forest river cardinal model 3825 - forecast is to drop to 28 tonight. rv park says we have to disconnect the fresh water line from their spigot. obviously I will put some water in the fresh tank. I will turn on the tank heaters. i'll turn the heater on low. do I need to worry about anything freezing and rupturing? what about the fresh water drain that extends below the trailer and is exposed? how can you put water in the fresh tank without water going down into the exposed fresh water drain?
CHICKDOE is online now   Reply With Quote
Old 08-22-2015, 12:37 PM   #2
RSchleder's Avatar
I would think you'll be fine with a low of 28 degrees. At most it'll be below freezing for a couple/few hours and the warmer water in the tank (warmer due to tank heaters) will keep the water above freezing. If it were going to be colder for a longer period of time, you can always open the fresh water drain so it just barely drips and the warmer water passing thru the valve will keep the exposed drain valve from freezing up.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 08-22-2015, 12:44 PM   #3
B47
Where are you camping with 28 degrees tonight?
Old 08-22-2015, 01:12 PM   #4
west Yellowstone - rv park says 28 tonight - yahoo says 30
Old 08-22-2015, 01:34 PM   #5
Ford Idaho's Avatar
If you follow such things It is just for one night as per the weather channel forecast.
It will be above freezing for the low Sunday and next week.
6666 above sea level, yes!
As for the drains I would just wrap them with some newspaper and duct tape.
Old 08-22-2015, 08:04 PM   #6
They tell me that if you have PEX lines they can freeze and not burst. I will find out sometime when winter comes
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 08-22-2015, 08:12 PM   #7
We've camped multiple times in the upper 20s and did nothing to prepare. If it were me, I wouldn't worry at all. 28-30 is not a hard freeze.
KFX450RXC is offline   Reply With Quote
Old 08-22-2015, 08:22 PM   #8
They told you the truth the lines will (Probably Survive) but the (Fittings and End Caps) will break ! Youroo!!
Old 08-22-2015, 08:23 PM   #9
When you disconnect your hose from the CG spigot, drain it or bring it inside, as it will freeze if left outside with water in it. If it does, you won't get water right away in the morning.
2011 Traverse LT, 3.6L, FWD
Old 08-22-2015, 08:49 PM   #10
mjones12's Avatar
Agree with KFX. A couple of hours of outside air at 28 degrees will not bring your water temp down to freezing.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
