Old 09-30-2012, 05:16 PM   #1
JCamper's Avatar
Jack stands during the winter???
Anyone put their TT up on stands through the winter? I'm looking for advice on avoiding the flat spots on my tires while the coach sits for the next 6 months.
I have read mixed suggestions on whether to jack up, or not to jack up, and where. (Frame/Axle)
I have a tandem axle and would think that a jack stand directly under each spring would be best.
Thanks in advance for the help.
BTW I'm a 2013 Tracer (Prime Time) 3150 BHD if it helps.
JCamper is offline   Reply With Quote
Old 10-01-2012, 07:58 AM   #2
Wanna Be Camper
SaskCampers's Avatar
I air the tires abt 5psi over, then run the trailer up on 2x10's and then put tire covers on them. Have had 0 issues with this method for many years.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-01-2012, 08:01 AM   #3
Would put the jack stands under the frame where the front & rear spring hangers attach and take the load off the tires and the springs.
Old 10-01-2012, 09:41 AM   #4
hotrodj125's Avatar
Thats what I was thinking of doing too-- stands under frame by front and rear spring hangers-- thanks for helping me finalize my thought toooo.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 10-01-2012, 11:22 AM   #5
Triguy's Avatar
FWIW - I also do not jack our trailers during winter storage (typically from mid-November - mid-March) and we have not experienced the problems with flat spots or issues with the springs.
However, I will check the inflation and re-inflate once or twice a month as needed, use boards under the tires, and use covers.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
axle, jack stands, winterize, tracer
