Originally Posted by Herve Mann
So, after having been "blown up" by a four old China Bomb, having to change it out with the spare on a bridge on I-70 in Ohio using the ramp method, I am in the process of having ALL the Castle Rock tires replaced. The question is: how does one jack this thing up? Dexter adamantly states do not jack in the axle. Everything else says use the frame. There's a little problem with that. It seems that Shasta in their infinite wisdom ran the propane lines right down the bottom of the frame. Thanks in advance.
Herve
Herve, it would be easier to understand the problem if you had posted pictures. My suggestion may be impossible or irrelevant.
Why don't you make a block to bridge the propane line and place that on the jack? If it's a small line, you could just cut (router or dado) a groove down the center of a 2x4 or 2x6. Or you could nail two 1x2 segments to a 2x6, spaced enough to clear the line and still contact the frame.
If it's iron pipe, just nail two 2x2 segments to a 2x6.
