Old 11-25-2015, 10:00 AM   #11
We've always used Bounce dryer sheets placed all around the inside and have never had a mouse. We've done this for many years. Plus when you open it in the spring it smells great-unlike the odor of moth balls.
hondo is offline   Reply With Quote
Old 11-25-2015, 11:57 AM   #12
I use D-con in the storage areas. No problems. Good sealing also helps.
Harkerr is offline   Reply With Quote
Old 11-25-2015, 12:04 PM   #13
alot of people I know swear by this: Fresh Cab #1 Botanical Rodent Repellant, 10 oz. - For Life Out Here
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 11-25-2015, 12:07 PM   #14
Keeping out the rodents.
We have used ORIGINAL Bounce fabric softener sheets in our fifth wheel and our friends cottage to keep our the little critters. I put it everywhere when closing up. In cupboards, in refrigerator , stove, in corners, under furniture , between cushions etc. We have had extremely good results with this and it also leaves the rv smelling great. In the spring I just gather them up. You can still use them for the dryer but they will not suffice to use for the rodent problem again. The major scent will be gone but for the dryer, too much scent is not always a good thing. I have also heard about the essential oils of peppermint and that it works well also. With the fabric softeners, you can put them above curtains and in wheel wells also. Just thought we would tell you how it has worked for us.
vdroskamp is offline   Reply With Quote
Old 11-25-2015, 12:13 PM   #15
MilCop4523's Avatar
Originally Posted by Platokidd View Post
Tried just about everything, then i added this to my arsenal and haven't seen a trace of any meese.
Fresh Cab Rodent Repellent and victor pest-chasers
x 2
if you have a baited trap system - DON'T
it counters what the Fresh Cab does.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 11-25-2015, 12:25 PM   #16
I like the cat idea!
BRUCEANDCYNDI is offline   Reply With Quote
Old 11-25-2015, 12:25 PM   #17
The problem with using D con is after the mice eat it they go somewhere and finally die. You may not be able to find them but when they rot you will smell them.
Old 11-25-2015, 12:43 PM   #18
Flybob's Avatar
Please do not use poison to control rodents. Almost all of it works by causing the animal to bleed internally which makes it thirsty. It will leave you RV in search of water. The problem is that it then becomes a prime target for a hawk or owl as it is weakened. If eaten by the hawk or owl, they are now poisoned and will die or have brain damage.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-25-2015, 12:45 PM   #19
harleyguy's Avatar
Go under your RV and check for any areas where the propane lines or other lines enter the RV.. I use great stuff foam sealant with pest block to seal any area that has a space. Mice can get through areas the size of a dime. I also put down glue traps around the wheels, stabilizers and tongue jack. On the interior we use fresh cab and put down glue traps. Make sure to take out anything the critters can use to make their nest from like paper towels, toilet paper etc.
harleyguy is offline   Reply With Quote
Old 11-25-2015, 12:46 PM   #20
Canadian Full Timer
Love the cat!
We heard that chestnuts, with a couple holes drilled in them, scattered underneath the unit, would also work. Not sure about that as we have not tried it.
Cherokeerose is offline   Reply With Quote
