Old 09-27-2011, 05:46 PM   #21
Rugged Brown's Avatar
how long should you keep it charging if I remove the battery from the camper.. there are 2 settings on the charger,, 12v and 6v.. What do I use.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 09-27-2011, 05:50 PM   #22
caper's Avatar
1.5 amp battery maintainer at Princes Auto $29.99.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 09-27-2011, 05:54 PM   #23
TURBS's Avatar
if you buy a battery tender brand you leave it on till your ready to install it back in the camper .
Old 09-27-2011, 06:12 PM   #24
acadianbob's Avatar
Not sure what your charger is. You would need 12 volt unless you are charging 6 volt batteries (separately, not in series). But the big issue is, do you have a Smart Charger? This is the kind that senses the state of charger of your battery and backs off accordingly on the amount of charge. A "dumb charger" will just keep right on charging, boil the water out of your battery, and ruin it if you keep it plugged in.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 09-27-2011, 06:55 PM   #25
TURBS's Avatar
look on your battery it will say if its 6 or 12 volt . if its 12 then set charger to 12 if you have 6 volt which then you would have two batteries in series as last poster said then you would set it at 6 volt but only charge one battery at a time or leave them in series to charge.
Old 09-27-2011, 07:13 PM   #26
dretired's Avatar
My battery is 12 volt.. but should i disconnect it when going to florida for 2 1/2 months this winter .. i will be at a full hook up site at a rv park ??
dretired is offline   Reply With Quote
Old 09-27-2011, 07:37 PM   #27
Battery Charger
This is what I have. It has 2 settings 6v and 12 v. What should I use and for how long.
ID:	8217   Click image for larger version
Terry/Bernadette
Lily the Yorkie
Old 09-27-2011, 07:44 PM   #28
TURBS's Avatar
your camping with your camper ? if so leave it hooked up your camper has an on board charger on it !
Old 09-27-2011, 07:47 PM   #29
I plan to remove the battery for winter storage. Should I keep the charger on for 6 months I won't be using it?
Terry/Bernadette
Lily the Yorkie
Old 09-27-2011, 07:50 PM   #30
TURBS's Avatar
sorry rugged i was responding to deretired .
and yes to your question remove it and leave the charger on ! it has float mode you will be fine!
