Old 09-27-2011, 06:52 PM   #31
Rugged Brown's Avatar
Originally Posted by f1100turbo View Post
sorry rugged i was responding to deretired .
and yes to your question remove it and leave the charger on ! it has float mode you will be fine!
Thanks Turbo and set it at 12v correct?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 09-27-2011, 06:54 PM   #32
TURBS's Avatar
yes if your battery is 12 volt which i assume it is and if you posted that it was 12 volt earlier i missed it sorry .
12 volt setting is what you want
Old 09-27-2011, 07:32 PM   #33
Jack of All Trades
RJHuser's Avatar
Just remember - even with 3 stage intelligent converters and chargers, battery minders, etc. you must check the electrolyte levels in the battery every few months. Even with the best chargers there will be a loss of electrolyte over time.
Rick
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 09-27-2011, 07:35 PM   #34
TURBS's Avatar
Rick
I guess mine is a super special electro light saver since my battery is sealed
Old 09-27-2011, 07:53 PM   #35
Jack of All Trades
RJHuser's Avatar
Many batteries say they are "sealed", very few actually are. See if you can remove the covers over the cells.
Rick
Old 09-27-2011, 07:56 PM   #36
TURBS's Avatar
trust me there sealed
Old 09-27-2011, 08:30 PM   #37
Jack of All Trades
RJHuser's Avatar
Most sealed batteries (SLA - Sealed Lead Acid batteries) or gel batteries where the electrolyte is in a gelled state. These generally are smaller, low amp-hour low discharge rate batteries such as are used in UPS's, motorcycles, etc.
What most sealed batteries are are Valve regulated batteries.
In a valve regulated lead acid (VRLA) battery the hydrogen and oxygen produced in the cells largely recombine into water. Leakage is minimal, although some electrolyte still escapes if the recombination cannot keep up with gas evolution. Since VRLA batteries do not require (and make it difficult) to regularly check the electrolyte level, they have been also called maintenance free batteries. However, this is somewhat of a misnomer. VRLA cells do require maintenance. As electrolyte is lost, VRLA cells "dry-out" and lose capacity. This can be detected by taking regular internal resistance, conductance or impedance measurements. Regular testing reveals whether more involved testing and maintenance is required. Recent maintenance procedures have been developed allowing "re-hydration", often restoring significant amounts of lost capacity.
f1100turbo, I'm not saying your battery isn't sealed - I don't know what brand and model your batteries are - I'm just saying many batteries advertised and sold as "sealed" truly aren't.
Rick
Old 09-27-2011, 09:21 PM   #38
TURBS's Avatar
Sealed or not sealed 6 years plugged in 24/7 365 on my tt.
never an issue. Just sayin.
Old 09-28-2011, 07:38 AM   #39
KyDan's Avatar
Originally Posted by dretired View Post
My battery is 12 volt.. but should i disconnect it when going to florida for 2 1/2 months this winter .. i will be at a full hook up site at a rv park ??
No, just check the electrolyte level when you get there and then again
a month later.
Add distilled water if needed. I doubt you will need it.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 09-28-2011, 07:50 AM   #40
dretired's Avatar
keeping the rv plugged in
a month later.
Thank you ..will do !!
dretired is offline   Reply With Quote
