Old 09-26-2011, 05:21 PM   #1
dretired's Avatar
keeping rv plugged in
Is there any harm in keeping a rv plugged in, to a 120 volt house/garage outlet with a adaptor, for charging my 5th wheels 12 volt battery ??
dretired is offline   Reply With Quote
Old 09-26-2011, 05:49 PM   #2
no, as long as your converter doesn't cook the battery.
latner is offline   Reply With Quote
Old 09-26-2011, 05:51 PM   #3
wfmdfm's Avatar
Plugin
We were advised during our walk thru that if we keep it plugged in we need to keep a check on the battery fluid. The charger is very simple and will cheep charging and the fluid will boil out.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 09-26-2011, 06:18 PM   #4
TURBS's Avatar
I live mine plugged in 24/7 365 .
never had an issue.
most newer units have a 3 stage charging system as mine does
1st bulk charge
2nd absorption charge
3rd float charge
Old 09-26-2011, 06:21 PM   #5
KyDan's Avatar
I'd be really surprised and disappointed if a 2011 5th wheel didn't have
a decent 3 stage charger.
It won't "boil the water" out of your battery!
Folks are all too often given old/outdated info on the walk thru.
I think you are one of them!
IF you want follow up go jot down the make and model number of
your on-board power center/converter and tell us what it is.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-26-2011, 06:25 PM   #6
flyrotor's Avatar
Ditto: mine has been plugged in for 18 months minus camping without hook-ups. Only issue was when I first bought the trailer I thought I needed a regular battery charger, thought I bought a good 3 stage black and decker charger and fried the batteries --- dead--- dealer replaced them without question with new batteries and I have never again used the battery (B&D) charger, no issues since then.
p.s The fridge has been on almost for the duration that the trailer is not winterized, no issues there either.
flyrotor is offline   Reply With Quote
Old 09-26-2011, 06:31 PM   #7
TURBS's Avatar
kydan is correct ! It will not boil the water out !
My 2006 tt that i traded had a three stage charger on it as well . I had it for 6 years plugged in 24/7 365 still had original battery.
Old 09-26-2011, 06:32 PM   #8
(Kim)
Labzy's Avatar
What are the best brands of 3 stage chargers to get?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 09-26-2011, 06:36 PM   #9
TURBS's Avatar
what model of convertor do you have in your unit now ?
your convertor has a built in charger .
should look like this . or close to it .
Old 09-26-2011, 06:44 PM   #10
(Kim)
Labzy's Avatar
That looks familiar
However, I need to remove the battery while storing my TT over the winter, so I am in the market for a charger.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
