Old 01-10-2019, 01:59 PM   #1
King Jack Installation Question
We are thinking about replacing our factory crank-up TV antenna with a King Jack OA8501 antenna. Does anyone know if the King Jack installation requires enlargement of the roof hole on a 2016 Forest River Flagstaff Shamrock 19? If so, what is the best way to cut the roof? A jigsaw?
CountryRoads is offline   Reply With Quote
Old 01-10-2019, 02:07 PM   #2
Denver To Yuma In 90 Days
Skip that King/Jack and just get the King/Jack Batwing replacement head.
No hole cutting and works much better than the new omni-directional unit.
Only takes five minutes to swap and it's around $50!
Best upgrade I ever made!
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote
Old 01-11-2019, 12:15 PM   #3
antenna
Ditto on the antenna.
Also get the strength meter.
C.B.
cbvp is offline   Reply With Quote
Old 01-11-2019, 02:23 PM   #4
Thanks! We took your advice and ordered the replacement head and signal strength meter.
Old 01-11-2019, 03:00 PM   #5
Fulltime family RVer
With just replacing the head, does the signal meter need an extra cable ran? Or does it use the existing wiring?
Old 01-11-2019, 04:23 PM   #6
AquaMan's Avatar
You can attach it at any jack inside the RV. In my 5er, I attached to jack that was next to antenna, tuned, then disconnected it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 01-11-2019, 04:25 PM   #7
antenna
1) Use existing wire.
2) I used the existing power amplifier, not the one with the King Jack.
3)Meter goes between antenna and television.
C.B.
Old 01-11-2019, 04:32 PM   #8
C.B.
Same here...
All you need to do is to hook up the coax from the old batwing and aim it.
I also bought a signal finder from Camping World...
Old 01-11-2019, 11:24 PM   #9
Originally Posted by JohnD10 View Post
Same here...
Way cool. Thanks for sharing the alternative to replacing the whole sh-bang.
Old 01-12-2019, 12:47 AM   #10
No problemo!
And...don't forget to rescan the TV!
In my yard in Denver I went from around 40 channels with the batwing to over 80 channels with that King/Jack.
And in the mountains I got stations with it where the batwing never got any...
It's that good!
