Old 09-13-2015, 08:35 PM   #1
Knife disconnect switch
I am planning on installing a knife disconnect on my 12 volt battery. Should i place it on the positive or negative?
Thanks for your help.
dmac1951 is offline   Reply With Quote
Old 09-14-2015, 09:05 AM   #2
cogito ergo moo
Cowracer's Avatar
Don't do a knife. There are so many better (safer) disconects out there, that you really don't need a knife switch, unless you want to feel like Dr. Frankenstein whenever you throw it.
It makes not a whit of difference which side of the battery is disconnected, but for some reason, people generally tend to do the positive.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 09-14-2015, 09:42 AM   #3
Head Rambler
I agree with everything Cowracer said. It's standard practice to break the positive side here in the US.
Gotta go campin!
Old 09-14-2015, 10:43 AM   #4
AKA: 'tiredTeacher
awellis3's Avatar
Yes it is the standard practice, even if it doesn't make as much sense as breaking the ground circuit. However, every auto mechanic knows to disconnect the battery ground strap before removing engines or trannies. That, too, is standard practice.
I'd break the circuit with the single wire. Some trailers have two or three wires attached to the positive post. On those it makes more sense to switch the ground circuit (single wire).
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 09-14-2015, 11:21 AM   #5
Engineer of Crazy Train
ChooChooMan74's Avatar
Break the positive. If you break the ground and forget to turn It on, you lose the trailer breakaway. Also, if equipped, you will still have use of your power jack. I recommend a marine type switch.
http://campinglifewithmatt.blogspot....ct-switch.html
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 09-14-2015, 01:36 PM   #6
AKA: 'tiredTeacher
awellis3's Avatar
As they say, "'nuff said."
Wright and Penny
Richmond, Va.
Old 09-14-2015, 03:01 PM   #7
This is what I use I disconnect the ground first ATTACH]88662[/ATTACH]Click image for larger version
Name:	ImageUploadedByForest River Forums1442260851.033885.jpg
Name:	ImageUploadedByForest River Forums1442260833.562784.jpg
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
