Old 09-16-2013, 03:31 PM   #11
Be very careful with things like Goo Gone. They can damage the surface. I recommend WD40.
Old 09-16-2013, 06:38 PM   #12
Masondood's Avatar
Originally Posted by B47 View Post
Couple commercial products on the market -Goof Off is one if I recall the name correctly. Check whenever you use in an out of sight area first.
Goof Off is simply lighter fluid, and could melt the counter, I would recommend something like Goo Gone or WD 40
'79 corvette
'09 Harley Road King
'NO tow vehicle (yet)
Lovely Wife and Son, two terriers, and Ringo the cat!
Masondood is offline   Reply With Quote
Old 09-16-2013, 08:36 PM   #13
mduff's Avatar
Originally Posted by sheriff1 View Post
Wd40
X2
Have used on a number of surfaces successfully to remove adhesive residue.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 09-19-2013, 07:29 PM   #14
Wd40
I'll second that...
Steve & Brigitte
North Eastern Oregon
The Right Side of the State...
_______________________
2013 Surveyor Sport SP220
2014 Toyota Tundra Dbl
samsberr is offline   Reply With Quote
Old 09-19-2013, 08:20 PM   #15
phat phrog stunt crew
they sell in the auto parts store an eraser that goes into an electric(or cordless) drill. worked great getting factory adhesive off my sons s10 tailgate when he went for the smooth look. no harm to the paint, cost about 15 bucks and took him 45 minutes. brushes right off like pencil erasure left overs.
basically a quite large pencil erasure. works good getting bumper stickers off your camper too.
dwaynerz is offline   Reply With Quote
Old 09-19-2013, 08:44 PM   #16
That "power eraser"'will probably melt the Corian.
Old 09-19-2013, 08:52 PM   #17
B47
Just how big can the residue patch be? Ours was probably 3 by 4 inches total and while ours sticker didn't leave any residue, I can understand some don't, but how difficult can removing it be.
If you don't want to use Goof Off or something similar, try the WD 40.
Remember these countertops are meant to take punishment. Doesn't the label have some suggestions for removing residue?
Old 09-19-2013, 09:21 PM   #18
isnt corian resistant to heat? isnt it thicker than a base coat clear coat on your car?
Old 09-19-2013, 09:23 PM   #19
Oklahoma Proud
MillerTime's Avatar
Yes it will. It also wont work on painted plastics, single stage paints or cheaply done paint jobs.
Ive used acrisol based adhesive removers for years, on auto paint, wood floor, fiberglass bath tubs, glass, plastic trim and moldings on vehicles, fabrics, granite, and it works on hand and feet (when someone gets hold of a sticky trap), and im sure some other stuff. No ill efects yet- except real fresh ( like less than 48 hour) auto clear coats on some brands will make it a little cloudy on the surface and a little soft again.
Op heres the stuff I mentioned before. Its not acrisol based but is very good and is what I use on all the above at work and home!
Old 09-20-2013, 06:38 AM   #20
Wd40
drc343 is offline   Reply With Quote
