Old 11-20-2011, 02:24 PM   #11
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by Ovair View Post
I doubt the dealerships remove them from the RVs on their lots.
Most dealerships are now removing TVs from their RVs upon arrival to avoid problems with theft. Many RVs come standard with 26"-42" flat panel TVs these days, so they're easy for dealers and customers (and thieves) to remove.
In terms of temperature, I think it depends on what part of the world you're in. Unfortunately, the same can probably be said for theft...
Wildcat Chris is offline   Reply With Quote
Old 11-20-2011, 02:29 PM   #12
fonzie's Avatar
Lightbulb
How to Store an LCD in Freezing Temperatures
By Jason Cooley, eHow Contributor updated November 25, 2010
Print this article
An LCD TV should not be stored in temperatures below minus 20 degrees F.
LCD displays use liquid crystal fluid in the display. Like all other fluids, the liquid crystal fluid can freeze in cold conditions. It's important to be aware of what conditions can ruin your LCD display. Ideally, you should store your LCD in temperatures between 40 degrees and 100 degrees Fahrenheit to keep the liquid crystal fluid from freezing. You can still store the TV in colder weather, but there are some rules to follow.
Related Searches:
TV Vizio26 Inch LCD TV Best Price
Difficulty: Easy
Instructions
Things You'll Need
Blanket or cardboard box
1
Cover the TV with a blanket or wrap a piece of cardboard around it large enough to cover the screen. No matter what the conditions, your TV is always susceptible to being scratched while in storage, so it's important to cover the screen to protect it.
2
Store the TV in temperatures above minus 20 degrees F. Different manufactures have different weather limitations for their products, but, according to RV Road Trips, no manufacture has a temperature limit lower than minus 20 degrees.
3
Give the TV 24 hours to acclimate to the warmer surroundings before use if you store the TV in temperatures lower than 40 degrees. It's not a good idea to immediately take your LCD TV from extreme cold to a much warmer environment.
Read more: How to Store an LCD in Freezing Temperatures | eHow.com How to Store an LCD in Freezing Temperatures | eHow.com
Fonzie
Old 11-20-2011, 04:25 PM   #13
I keep my lcd tv for the winter inside the house. We enjoy it in one of our bedrooms while the trailer is in big sleep for the off season.
capucine is offline   Reply With Quote
Old 11-30-2011, 08:52 PM   #14
j2detroit's Avatar
I know some people say its OK but I take ours home not only because of theft potential but because we get down into the 40s below zero yes -40 or colder and that's without the wind chill
j2detroit is offline   Reply With Quote
Old 11-30-2011, 09:57 PM   #15
Wanna Be Camper
SaskCampers's Avatar
Same here -35 to -40 but ours stays in the trailer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
