I have a 2013 Rockwood 2109 that has a small hole in the bottom of the fresh water tank. Does anyone know of a product I could use to fix it? I have tried a product called pig putty that has worked for me on many different leaks but it won't stick to whatever this tank is made of. Any thoughts would be greatly appreciated.
Tom & Terri
2012 GMC Yukon
2013 Roockwood Mini Lite 2109s
If the tanks are black they are ABS plastic. Same as plumbing pipes etc. You should be able to get the glue that is used on these pipes an maybe an end cap that you can cut to size and glue over the hole.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
