Old 09-27-2016, 11:18 AM   #1
Leaky shower nozzle
Is there a shower water cut off in a 2008 Lexington 255 gts? Leaks whenever any water pressure is on. Had to tape hose and apply kinks to hose in a couple of places. The wall access did not show cutoffs. Do I just replace faucet set up ?
snags1962 is offline   Reply With Quote
Old 09-28-2016, 08:45 AM   #2
The shower nozzle head is leaking when the hot or cold water pressure is on in the shower ? Or when water pressure is on to the camper ?
2017 Forester 3011DS (On order)
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 09-28-2016, 08:50 AM   #3
I just had my shakedown cruise with my trailer and I have the same problem. It started after the first shower was taken, now, whenever the pump is on, the shower sprayer leaks. I'm taking it in for warranty service.
2017 Cruise Lite 251SSXL
2012 Dodge Ram 3500 4x
2014 Arctic Cat Trail
seagrace is offline   Reply With Quote
Old 09-28-2016, 09:25 AM   #4
Flybob's Avatar
Some shut off valves allow a small amount of water to flow be design ( not a leak) for soaping up . You can easily replace it with a positive shut off valve.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-28-2016, 09:26 AM   #5
Thanks Seagrace
Let me know what happens...my rv is a 2008 and so no warranty. Hope it is something I can repair fairly easily.
Old 09-28-2016, 09:37 AM   #6
PhoneDude 8289's Avatar
Could be some trash collected in the faucet seats. Remove the handles and cartridges, start the pump to flush out the lines, clean the cartridges and reassemble. If that don,t do it a couple of new cartridges or faucet might be in order.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 09-28-2016, 09:39 AM   #7
clr
Are you talking about the inside or outside shower? There is no shut off valve in any RV that I have seen for the showers. If water is leaking out of the shower head one of the faucet valves is leaking. You in all probably you have a bit of dirt or grud stuck in the valve seat. I would shut off the water pressure and take the faucet apart and look that would be easier for me than taking the unit back to the dealer.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
leak, show, shower
