Old 05-02-2016, 06:27 AM   #1
JohnF's Avatar
Left, Right or Center?
When backing or pulling into your camping site, which position do you take? Do you like as much gravel/pavement as possible by your entry door (left), or do you prefer to have the grass/dirt nearby (right) so when you step outside you feel you are really camping, or do you go to the center and share the pavement with the ďutilityĒ side?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 05-02-2016, 06:35 AM   #2
jeff64's Avatar
I am usually back as far as possible where my awnings don't hang up in any trees and so my slides don't hit the utility posts and where I don't have to lift 1 side 4" because of the off level of the spot
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-02-2016, 06:39 AM   #3
Assuming there aren't obstacles that interfere with slide out or awning, I usually choose whichever is the closest to level. If the whole spot is level, and there are no concerns with obstacles, I usually park so that I have as much site as possible on the door side.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 05-02-2016, 06:45 AM   #4
(Dry Huunday)
DreiHunde's Avatar
Pretty much this, As far back and as far over to the "utility/driver side" as possible!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
Old 05-02-2016, 07:01 AM   #5
If you are using a Park for the First/Last time it is Sometimes a Crapshoot in regards to "Where and What" you can/Have to do! It makes NO difference if its a "State Park/County Park/COE Park/RV Resort/Fed Forrest/WalMart" there are places where Some units just "Ain't Going to Fit Right"! Youroo!!
Old 05-02-2016, 08:35 AM   #6
Prime Member
Ditto what everyone else said with one addition. I want my drain pipe at least 5' away from the site's sewer dump so my sewer hose can be as straight as possible. Any closer and I have put a 'S' bend in it.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 05-02-2016, 08:52 AM   #7
I park so my awning is as far away as possible from the fire pit. A lot of campgrounds have "fixed" pits and I don't want my awning damaged by a spark. Other than that I then look at where sewer is if full hook up. Then I check for slide clearance.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=11
Electra glide is offline   Reply With Quote
Old 05-02-2016, 09:51 AM   #8
I'm with the "as far ulitilty/street side as I can get to allow as much "yard" space as possible. When the DW and I pull into a campsite, after the initial back in, I will leave the rig running, get out and scope out the best position with my wife and then make any adjustments that we both think will give us the best positioning of our RV.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 05-02-2016, 11:27 AM   #9
Some guy in back...
With three slides and two awnings, I optimize for clear space. I also don't worry about being in "straight" Sometimes a little angle makes all the difference!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 05-02-2016, 11:42 AM   #10
asquared's Avatar
Positioned however I can best fit 4 slides and an awning on a 40' fiver around all obstacles while optimizing outside camping space and location of hook ups. The truest answer would really be where DH tells me to put it.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
