Old 05-25-2016, 10:08 PM   #11
Navymike's Avatar
Thank you for the input. The reason I ask is because I know the newer trailers have a greater distance between wheels and I just thought I would get a simple answer. I sloped 3 boards 1 at 4' and 2 at 3'
I also cut 4 18" 4x4 (one for each stabilizer) and 2 14" 4x4 for the tongue. I also have a couple of 2x6 pieces for the tongue as well.
Navymike is offline   Reply With Quote
Old 05-25-2016, 10:11 PM   #12
Professional Curmudgeon
Originally Posted by rockfordroo View Post
And why the OP said he had a 253rks.
Which, oddly enough, is what I have. I even went outside to measure.
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is online now   Reply With Quote
Old 05-25-2016, 10:21 PM   #13
Navymike's Avatar
Did they have the wider tire distance in the 2014 compared to the newer rigs?
Old 05-25-2016, 11:07 PM   #14
Nope, they are exactly the same.
Changes for 2017 include:
1 drawer under dinette bench
LED lighting under awning
Solar power prep and
Rear camera prep
And a Continu.us omnidirectional tv antenna
That's pretty much it.
Old 05-26-2016, 12:06 AM   #15
Yea I am thinking about picking up some 1"x to supplement and do some finer adjusting. good luck with your leveling! Enjoy your trailer!
Jason
2000 Ford F-250 V10
2017 Salem Cruise Lite 273QBXL
2016= 5 Nights Camped
Jasdow77 is offline   Reply With Quote
Old 05-26-2016, 06:36 AM   #16
davel1971's Avatar
I carry some foot long 1x6 pieces. Use them quite often. Trying to level in 1.5 inch increments seems to often be a tad to little or to much.
David & Lynn
Old 05-26-2016, 07:20 AM   #17
Canadian Member
itat's Avatar
I know he OP has already bought and cut his boards but I would suggest that you leave the boards long enough that you can place chocks on both ends and have the chocks fully on the boards. That leaves the space between the tires for X-chocks.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 05-26-2016, 07:21 AM   #18
I cut one 2x10 (see Radio's comment) as long as I could and still fit in the bed of my truck with the tail gate closed. I use lego blocks on top of the board if needed. Wvrond, can you use the Anderson levelers on top of a board, or will they slide?
Baldicon is offline   Reply With Quote
Old 05-26-2016, 08:39 AM   #19
There is a tendancy for them to slide on any smooth surface. Some folks have put adhesive treads on them to counteract this, but I've never had a problem on pavement, concrete or wet grass. I believe that if I were going to make a board to go under them on really soft ground I would apply a traction strip to the top of the board to enhance traction.
Old 05-26-2016, 10:25 AM   #20
I bought 2 sets of these, one for each tire. These will work with any TT, are alot lighter and stow easier.
http://www.amazon.com/Tri-Lynx-00015...eveling+blocks
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
leveling
