Old 05-26-2016, 10:03 AM   #21
I use a cow mat cut into 3 ft x 1 ft strips. Works great, can stack them as high as you want and they don't slide around, easy to clean before storing and indestructible.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 05-26-2016, 10:29 AM   #22
You will still need a board or something solid to set them on, they will sink in soft dirt or sand.
Baldicon is offline   Reply With Quote
Old 05-26-2016, 10:40 AM   #23
I have been using them for years and never had a problem with that.
2007 Surveyor SV230
Old 05-26-2016, 10:43 AM   #24
Our method needs No boards or worry about axle spread! They have a Big foot print and lite weight easy to clean and Not effected by water! Youroo!!
ID:	109072   Click image for larger version
Old 05-26-2016, 10:55 AM   #25
boondocking, you snuck your post in before my reply made it! I was referring to the Tri-Lynx leveling blocks that timfromma was talking about. Timing is everything.
Old 05-26-2016, 11:41 AM   #26
Retired
MainelyUS's Avatar
WRVOND..I have to check out the Anderson levelers....seems like less hassle then placing the correct number of "boards/lego blocks" under the tires.
With that set if your are going to build a set of landing board (s) might sure the length takes into account the placement of wheel chocks. I added 8" on both ends to the required length. I agree with Baldicon use a 10" board. We used 5/4 x 10" PPT broads they fit in the bed of the TV and are easy for DW to maneuver...but the Anderson levelers look like a good investment. Can you use the Anderson levelers to change a tire???
Happy Trails
Thank a VET this weekend
2015 Windjammer 2618VS
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
Reese Strait-Line WD
MainelyUS is offline   Reply With Quote
Old 05-26-2016, 11:50 AM   #27
Originally Posted by Navymike View Post
I am getting things ready for our 253rks which arrives tomorrow. Cutting up some 2x6 for leveling boards. What is the min length needed to put both tires on the board?
Thanks.
Mine are cut 60"...works good
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 05-26-2016, 11:55 AM   #28
I have 2x8x24" (several of them) all stored in one trailer compartment.
Back into site, check level. Determine how much lift is needed on one side (usually only one board per tire). Place one board next to each tire to be lifted. Pull ahead enough to clear front board. Wife pushes both boards straight into wheel path. Backup onto both boards. Trailer leveled.
Been doing this for the past 5 years now and it always works. If 2 boards are needed (or one board on one tire only to raise by 1") then modify placement of boards accordingly. Using the method described above I've never "missed" hitting a board. Will not matter if axles are 30", 32" 48" apart; place boards so that middle of 24" span is directly under the hub of each wheel.
J.
jcrayford is offline   Reply With Quote
Old 05-26-2016, 12:19 PM   #29
Brim1162's Avatar
It's a trick question 😜
Brim & Dee Cary
Arlington Texas
Flagstaff 8528IKWS
GMC 2500
Brim & Dee Cary
2015 GMC Sierra 6.0 Flex
2015 SL 85281KWS
DFW Texas
Brim1162 is offline   Reply With Quote
Old 05-26-2016, 12:42 PM   #30
Occasional campers
Levelers
Originally Posted by timfromma View Post
I bought 2 sets of these, one for each tire. These will work with any TT, are alot lighter and stow easier.
Amazon.com: Tri-Lynx 00015 Lynx Levelers, (Pack of 10): Automotive
x2 on these. I have these and like them; they give more flexibility than most board arrangements, particularly if the site is off-level both side-to-side and lengthwise. A little sinking if it's really muddy, but nothing so far has been too bad.
Ray and Ann is offline   Reply With Quote
leveling
