Old 05-26-2016, 01:45 PM   #31
Professional Curmudgeon
Originally Posted by MainelyUS View Post
WRVOND..I have to check out the Anderson levelers....seems like less hassle then placing the correct number of "boards/lego blocks" under the tires.
With that set if your are going to build a set of landing board (s) might sure the length takes into account the placement of wheel chocks. I added 8" on both ends to the required length. I agree with Baldicon use a 10" board. We used 5/4 x 10" PPT broads they fit in the bed of the TV and are easy for DW to maneuver...but the Anderson levelers look like a good investment. Can you use the Anderson levelers to change a tire???
Happy Trails
Thank a VET this weekend
I don't believe they have enough lift to get the other wheel clear of the ground. Anderson does make one that is intended to serve that purpose, though I've never tried it. I carry an hydraulic bottle jack that will work for both the TT and my truck.
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 05-26-2016, 01:54 PM   #32
Originally Posted by Baldicon View Post
boondocking, you snuck your post in before my reply made it! I was referring to the Tri-Lynx leveling blocks that timfromma was talking about. Timing is everything.
Guess I"m just to fast at the draw.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 05-26-2016, 02:01 PM   #33
MainelyUS's Avatar
wrvond thanks for the info...I carry a HBJ as well.
HappyTrails
2015 Windjammer 2618VS (Hibernating)
2016 Silverado 2500HD Z71 6.0L 4:10 gears w/max. tow package
Reese Strait-Line WD
MainelyUS is offline   Reply With Quote
Old 05-26-2016, 02:15 PM   #34
Originally Posted by Ray and Ann View Post
x2 on these. I have these and like them; they give more flexibility than most board arrangements, particularly if the site is off-level both side-to-side and lengthwise. A little sinking if it's really muddy, but nothing so far has been too bad.
Front to back leveling is fixed with your tongue jack.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 05-26-2016, 03:25 PM   #35
Gripper's Avatar
Originally Posted by jcrayford View Post
I have 2x8x24" (several of them) all stored in one trailer compartment.
Back into site, check level. Determine how much lift is needed on one side (usually only one board per tire). Place one board next to each tire to be lifted. Pull ahead enough to clear front board. Wife pushes both boards straight into wheel path. Backup onto both boards. Trailer leveled.
Been doing this for the past 5 years now and it always works. If 2 boards are needed (or one board on one tire only to raise by 1") then modify placement of boards accordingly. Using the method described above I've never "missed" hitting a board. Will not matter if axles are 30", 32" 48" apart; place boards so that middle of 24" span is directly under the hub of each wheel.
J.
First time ever adding a pic. May help reduce number of boards you carry and works great! I have x chock to. Hope this helps and works. Ends are angled
Essex County
Southern most area in Canada
2015 F150 XLT Sport 5 ltr V8
2011 Flagstaff classic 31.5'BHDS
Gripper is offline   Reply With Quote
Old 05-26-2016, 03:30 PM   #36
Gripper's Avatar
having issues with pic I will figure it out
Essex County
Old 05-26-2016, 03:38 PM   #37
Gripper's Avatar
Trying pic upload again
Essex County
Old 05-26-2016, 03:40 PM   #38
Gripper's Avatar
Pic two trailer beside house on patio stones
Essex County
Old 05-26-2016, 03:44 PM   #39
That is a pretty cool idea!
2007 Surveyor SV230
Old 05-26-2016, 07:02 PM   #40
I made some new ones last month. Used two 2x8x8. I made three 3' pieces and four 2' pieces. I cut 45 angles on the ends and reversing the angles on each end some I can line up several boards if needed. This also prevents the boards from tipping up when I drive over the joint. Easily stackable for added height.
Sierra360PDEK is offline   Reply With Quote
leveling
