09-14-2015, 01:45 PM
Let me vent about no vent!
I have a forest River Grey Wolf 19RR. When I fill the water tank, water pours out of the tank vent down under the camper. About 5 gallons pours out until the water level in the tank reaches below the vent. I just crawled under the trailer to see if the vent hose was disconnected.
THERE IS NO VENT HOSE!
Simply the tank vent elbow with nothing attached.
Then I pulled the water fill device to see if the vent hose was there but just never attached...NOTHING!
In fact it's worse, the connection where the vent hose is supposed to attach is sealed with caulk!
Whats up with this? Am I missing something here? Seems bad that the fresh water tank vent would simply be open to the elements, underneath the trailer where all kinds of nasties could get into the drinking water.
09-14-2015, 01:59 PM
Yes, you are missing something! ... a vent hose. I can't believe someone sealed the hole with caulk!! Lame! Did you buy this new?
09-14-2015, 02:51 PM
No, it is a 2011, one owner that was never registered! It is like new condition. As I fuss around and modify stuff, I'm shocked at the shoddy workmanship!...And the lack of a simple vacum cleaner to clean up after they cut holes everywhere. They even leave the piece they cut out behind. Couldn't take 5 seconds to throw away the trash. Just leave it under the hot water heater or next to the pump.
So glad I didn't pay retail!....There would be hell to pay!
09-14-2015, 03:08 PM
How do you know the previous owner did have his b mitts in this?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-14-2015, 11:11 PM
My 2012 Cherokee is the same. I added the vent hose myself.
2002 Chev 1500HD
2012 Cherokee 235B
09-14-2015, 11:22 PM
Plain Old Member
Not all, but some are actually built this way. Not necessarily the best way or right way, but a way.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
09-14-2015, 11:24 PM
Plain Old Member
Oh, welcome to the world of RVs. Consider the trash they leave behind a bonus. Sometimes you can get quite the collection of screws and electrical stuff.
09-14-2015, 11:54 PM
Heck, I've even had tools left in mine when it made a return trip to the factory.
2014 Sabre 34REQS-6
09-15-2015, 01:12 AM
Just a member
Near brand spanking new - looking for rodent entry points.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
09-15-2015, 02:43 AM
My 2013 Columbus is built this way as many of the new ones are. I put a valve on mine so it does not siphon out. I rarely use my fresh water tank.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
09-15-2015, 06:05 AM
A Dealer, not the Dealer we bought from New replaced the (Fresh water Tank,the tank heat pad,the Vent tube,for a longer one,the water Pump,and then I replaced the Fresh water fill/vent assembly on the outside that broke)! That was when it was New,then when we took it back to its Birthplace for the Slide issue I ask if they could Place the FW pump pickup line to the Sump area on the FW tank instead of (2" up the side) then we would have ALL the water usage from the Tank,they gladly changed the location for us! After all of this when we fill our FW tank (Slowly) until the water comes out the (Vent/Overflow outlet) by the Fill cap location,we have a FULL FW tank and No siphoning! Youroo!!
09-15-2015, 06:47 AM
Georgia Rally Coordinator
Well that's one way to get it fixed. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
09-16-2015, 01:17 PM
I bought a 21rr brand-new and it was the same way. I bought a piece of vinyl hose and two clamps and fixed it myself. I bought a 27rr and had to do the same thing. It is an easy fix but I don't understand why they don't do it at the factory.
