Old 11-08-2012, 10:25 PM   #11
Originally Posted by f1100turbo View Post
They are to equalize against rough or rolling terrain NOT for excessive tilt forward or rearward because UN level trailer.
The more the unit is out of level whilst towing the more stress that's applied to the axle .
Turbs
One inch out of level is not excessive.
The OP will be fine.
bakken is offline   Reply With Quote
Old 11-09-2012, 10:30 AM   #12
Dave_Monica's Avatar
An inch high or low is as close to level as you can get. If you wanted it to be perfectly level, you'd have to drop the hitch or raise the pinbox 1/2". The smallest pinbox adjustment is 1" and on my hitch the smallest adjustment is 1 1/2".
To the OP, if you had the drop your hitch to the lowest level, how was the clearance between the truck's bed rails and the fiver's overhang?
Dave
Old 11-09-2012, 10:37 AM   #13
acadianbob's Avatar
Originally Posted by MillerTime View Post
I find that mine has less chucking when higher in front then level. But I live and travel by the dreaded I-40 east of OKC so chucking is a big problem around here.
That makes sense as you would be transferring more weight to the trailer axles and off of the truck's payload.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
