Old 05-31-2015, 05:34 PM   #11
JPS0929's Avatar
X2 on the andersons. I also trimmed my second one couldn't be easier.
JPS0929 is offline   Reply With Quote
Old 06-01-2015, 05:26 PM   #12
This may be a dumb question, but shouldn't each tandem wheel on the same side be raised on their own leveler and not just the one wheel as in youroo's pic? If so, I don't think that I have enough room between the tires to fit a leveler.
jwalt313 is offline   Reply With Quote
Old 06-01-2015, 05:31 PM   #13
Ford Idaho's Avatar
If you look at the picture you mentioned tight like you will note both tires ARE off the ground.
Old 06-01-2015, 06:18 PM   #14
Thanks Ford Idaho. Obviously, I'm a newbie. Can I assume then that, if I raise the rear tandem tire by putting the leveler behind the rear wheel as in the photo and back up, the front tandem tire will come up off the ground as well? Then I put the other leveler under the front side of the raised front tire to keep it raised? I was thinking that I had to put a leveler behind each of the tandem wheels and back up the trailer.
Old 06-01-2015, 06:25 PM   #15
Ford Idaho's Avatar
Yes you can lift one wheel by running the other up a ramp, people do this to change out a flat tire.
I will guess he pulls up too far, places the other and backs up till it is level and chocked at the same time.
Old 06-06-2015, 07:52 PM   #16
Travler's Avatar
Search this item on Amazon or camping world.
Andersen-3604 Camper Leveler
Travler is offline   Reply With Quote
Old 06-08-2015, 11:52 AM   #17
I have many of the plastic ones but I prefer
wood, by far. Good luck
whj77372 is offline   Reply With Quote
Old 06-10-2015, 05:23 PM   #18
on the Lynx
Papa GLS is offline   Reply With Quote
