Old 10-22-2015, 02:04 PM   #1
leveling
I have a 2013 Flagstaff 8528RKWS. It seems when I go and level I am in the bubble side to side. As soon as I put the slide out I feel like I am lower on the slide side. I know it shouldn't make a difference but does anyone else experience the same thing? I guess the slide out has enough weight that I am going to have to compensate for it. Any thoughts or revelations?
Getting frustrated!!!!!!!!!!!
Drexel 2012 is offline   Reply With Quote
Old 10-22-2015, 02:21 PM   #2
Pickin' & Campin'
Yep... it happens especially if you have just one larger slide.
You can 'cheat' the bubble a little to the high side (slide side) so when you put out the slide, you are level. (WOW, say that 10 times fast!)
I have three slides.
When I open the two smaller ones on the left, it leans just a little that way (oh so slightly) but when I extend the larger slide on the right, I'm back level.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 10-22-2015, 03:22 PM   #3
ColoradoRick's Avatar
Yes, my Rocky also has just one big slide out and does make a difference.
We usually are on level ground when camping (mostly Colorado State Parks) but I still will drive up on leveling blocks to bring the side-out side up an inch or so.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-22-2015, 03:27 PM   #4
Jestercyco's Avatar
I always level with the slides out. Some people say you do not have to, but we have 5 slides on our unit. When I do that, it does not move or get out of level. Our unit does have the 6 point auto level.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 10-22-2015, 03:30 PM   #5
TURBS's Avatar
Jester
I was told to auto level level with slides in, then after level slide them out.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-22-2015, 03:47 PM   #6
Jestercyco's Avatar
I did do that with out sliding them out for the first 6 months and it always was moving. I put pads under each ram and got as low as possible shortest extension but, it still was moved to much form the DW. I started leveling with the slides out, and is does not have any movement. I have done it that way since then.
Jester
Old 10-22-2015, 03:49 PM   #7
TURBS's Avatar
Jester
Did you try auto level again when you thought it was moving?
TURBS
2008 duramax
2015 columbus 320RS
Old 10-22-2015, 03:58 PM   #8
I have a 2012 Flagstaff 8528RKWS and level with the slides in or out and it makes no difference. Of course I DO NOT PUT any blocks under the jack pads other than the Lynx blocks that are covered with alum and bolted to them. I try to get the legs as vertical as possible. I also have electric jacks in front of the axles which also now have the alum covered Lynx blocks bolted to the pads.
Name:	Front landing jak pad.JPG
ID:	92542   Click image for larger version
Name:	Rear stabilizer pad.JPG
ID:	92543   Click image for larger version
Name:	Reinforced Stab Jack Leg.JPG
Old 10-22-2015, 04:02 PM   #9
TURBS's Avatar
Like yourself Your's is so full of crap it can't move!
TURBS
2008 duramax
2015 columbus 320RS
Old 10-22-2015, 04:29 PM   #10
I've always heard the exact opposite. The less you have to extend the jacks, the less they'll wiggle. Although that may only apply to scissor jacks.
Iwritecode is online now   Reply With Quote
leveling
