Old 02-27-2015, 06:38 AM   #1
danielabram71's Avatar
Leveling blocks.
Ok we got to go camping about 5 times last year do to our camper being delivered later then we was told. I carried 3 2*6 boards around to level with. This year I was going to try the square stack blocks. My question is if you have to put some under all 4wheels how do you chock the wheels?
danielabram71 is offline   Reply With Quote
Old 02-27-2015, 06:52 AM   #2
Like this! and place X-Chock on the other side! Youroo!!
ID:	70354   Click image for larger version
Old 02-27-2015, 06:56 AM   #3
Ashley's Avatar
There may be something simple about this that my Simplistic Mind isn't seeing, but if you're "Leveling" with them why would you ever have some under all four wheels?
Before I get pounded by someone who knows more about camping than me, I'm just asking the question for my own knowledge.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 02-27-2015, 07:37 AM   #4
Evidently my mind is just as simplistic as yours Ashley. Any way, like youroo said, leveling blocks one side, x-chocks other.
Papa GLS is offline   Reply With Quote
Old 02-27-2015, 07:38 AM   #5
I carry 4 2x6's in my pass thru storage, and I use them under the low side tires only as needed to level. I have 2 sets of the leveling blocks, but I use them under the stablilizers and also under the steps if I have enough. I usually throw a couple 6x6 blocks in the back of the pickup also just in case.
steveh326 is offline   Reply With Quote
Old 02-27-2015, 07:42 AM   #6
Has anyone tried the Anderson levelers? I know this has been addressed many times, but every one I talk to that use them say they are the cat's meow. Whole lot less to carry with you & take up less space & much lighter than the wooden boards we all have carried.
Old 02-27-2015, 07:42 AM   #7
Mainly because we found them left at a campground, we carry two sets of the orange leveling blocks. If we are not using them under the tires or the tongue wheel, we can use them under our supply of firewood, or under the bag of charcoal, to keep those things off the damp ground. (We go to FS campgrounds a lot, so this can be an issue.)
Ash and Jim
and Wee Dram the Westie
2014 Rockwood HW276; 2008 Ford F150 V8 5.4 ltr. King Ranch
AshnJim is offline   Reply With Quote
Old 02-27-2015, 07:51 AM   #8
WolfWhistle's Avatar
I still carry 1" x 8" (by 12") boards (about 12 or so) to level and sometimes to place under stabs. I have the Andersen lift, but haven't tried it yet... But, no matter how its blocked up or lifted, the BaL X-chock wil work. The make different models, depending on how far apart the tires are.
http://www.amazon.com/dp/B004L6AAUE/..._TE_item_image
Amazon.com: X-Chock Wheel Stabilizer - Pair - One Handle - 28012: Automotive
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 02-27-2015, 08:18 AM   #9
And this under the Steps!
Old 02-27-2015, 08:44 AM   #10
mjones12's Avatar
What would be the problem with putting X-chocks on both sides?
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
leveling, lock
