06-24-2016, 09:55 AM
#21
know before you go
no matter what method you use, I've found you can eliminate trial and error by knowing how much you need to raise the low side,.... I use a 2' level and 1/4" blocks on my rear bumper to know how much I need to raise(tt is 8'wide, so 1/4" in 2' = 1" of rise needed)...... works w/lego blocks, wood, even Andersen, w/Andersen I predetermined how many inches I need to pull forward to raise up on the Andersen to get a known height, I lay a yard stick on the ground at my open drivers door and watch it as I pull forward,...... knowing how much you need to rise works every time w/any device, no trial and error, back and forth,......
I'm using the Andersen now but am always willing to try something that may be better,.... someone mentioned the stall mats and I might try that someday,..... but knowing how much to raise is certainly a benefit,....... I just stack boards, lego blocks, or stall mat pieces to the needed height, or drive forward on the Andersen a known distance,...... gets me level every time, 1st time,...........
06-24-2016, 10:19 AM
#22
Originally Posted by OldCoot
Only have 3" between the tires on my trailer and with a little modifying to the Andersons, they work great!
I'm not even sure we even have 3"... but the Andersen levelers can be trimmed to fit. Up to 4" off the front (between holes 1 and 2) and beveled to suit.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
06-24-2016, 10:27 AM
#23
Just trimmed the corner off mine.
06-24-2016, 10:36 AM
#24
am i correct in saying you can pull onto or back onto these?
06-24-2016, 10:49 AM
#25
Yes. I usually pull onto them. Then when leaving, you can just drive off them!
2013 Rockwood Roo 23SS
2021Nissan Titan SV 4x4 w/integrated Tow package
06-24-2016, 10:52 AM
#26
after on place the wedge under it right?
I saw a video of the guy driving off the thickest end, trailer landed and bounced. Probably wont hurt anything but looked bad. could see that bounce popping open cabinets or something.
06-24-2016, 10:54 AM
#27
Do you have a single axle trailer or do you make your rear wheel "drive" over the front one when leaving?
06-24-2016, 10:59 AM
#28
I have 2 axles. When you drive off them, the front leveler ends up in between the two tires and is easily removed.
See what I mean at 1:10 in this video
06-24-2016, 11:12 AM
#29
What do you do when you need more than 4" of height?
06-24-2016, 11:40 AM
#30
find another site, .... one time using a BAL Leveler on a single axle Casita, I did need to use the total rise, about 5", but that wasn't at a campground, it was in a back yard, but the BAL did it,....
06-24-2016, 01:08 PM
#31
Pretty easy mod with a table saw and a belt sander. Took all of 30 minutes and it is permanent.
Had to modify mine as well. Only a couple inches between wheels on our TT. I just cut off about an inch from the skinny end and they fit just fine now. Starts off at like 3/4" inch thick now. Figure if I have to level any less than that it's good enough and I leave it as is. lol
2020 Ram 2500 Laramie Longhorn 6.4
2015 Flagstaff 27VRL
06-24-2016, 01:16 PM
#32
If you only need to go up a little, just use one leveler. One inch rise on one leveler raises the camper 1/2 inch.
06-24-2016, 01:51 PM
#33
The first time I used my Andersen Levelers I pulled forward over the big end as described. The rear one shot out the back clear into the forest (site surface was blacktop). I pulled forward very slow...which actually probably helped propel the leveler. Luckily no one and nothing got hit. I got brave and tried the method once again while leaving a gravel/dirt site...the forward leveler got jammed in between the tires (I've got one of those close fit setups that required trimming of the corners to fit). I still love my Andersen Levelers...I just don't "pull over" them any more!
I used stall mat strips before switching to the Andersens. I liked them much better than boards and legos, but they are heavy...VERY heavy. The mat I cut into strips was 98lbs.
I still carry a few small pieces for when the trailer just needs an inch or less and for when the Andersens are not quite high enough. I also occasionally use them as padding for my knees when kneeling on gravel or wet surfaces.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
06-24-2016, 04:09 PM
#34
youroo..... i am usually very good and figuring out how something works but your system has me stumped. Pull past level on one, then slide the other in place and level out?
guys, believe me, i hate boards, REALLY want the andersons, but i am by no means rich lol. yes sure i have the money but try to stick to somewhat of a budget but have already gone way past this year on the camper mod/accessory budget.
but on a good note someone has messaged me with a used set of andersons at a great price so, this weekend will be boards (maybe just the old short ones) and soon i will have used andersons.
You are 100% correct,over pull then place other ramp behind release brake and they "Self level and Chock" 2 Moves,it don't get any easier! Anderson is 4 moves! Youroo!!
06-24-2016, 04:16 PM
#35
Georgia Rally Coordinator
One move and I'm done. Why mess around. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
06-24-2016, 04:22 PM
#36
Anderson's only require you put them in front or behind the wheels and back until level and put the wedge in. Plus they are much lighter.
06-24-2016, 04:26 PM
#37
(Dry Huunday)
Anderson's only require you put them behind the wheels and back until level and put the wedge in. Plus they are much lighter.
Yep. Never had to make 2 moves, let alone 4.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
06-24-2016, 09:44 PM
#38
Andersons each have (2) pcs. so that is (4) pcs. total for a dual axle unit! That is (4) Moves to place the Blocks and wedges! Like I stated our way is (2) moves Only (2) ramps! Youroo!! Also our ramps only weight 12# and only cost 39.00$
06-24-2016, 10:39 PM
#39
Youroo,
Who makes those? I looked online for something like those ramps but only find ones that have steps in them.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
06-25-2016, 05:10 AM
#40
Originally Posted by gectisme
Youroo,
Magnum, Bennackurn,Ill. USA! Sold by Harbor freight! 6" lift /10" wide /supports 16,000 lbs! SKU# 67722 We only use the Ramps not the second section! Youroo!!
