Old 06-24-2016, 09:55 AM   #21
know before you go
no matter what method you use, I've found you can eliminate trial and error by knowing how much you need to raise the low side,.... I use a 2' level and 1/4" blocks on my rear bumper to know how much I need to raise(tt is 8'wide, so 1/4" in 2' = 1" of rise needed)...... works w/lego blocks, wood, even Andersen, w/Andersen I predetermined how many inches I need to pull forward to raise up on the Andersen to get a known height, I lay a yard stick on the ground at my open drivers door and watch it as I pull forward,...... knowing how much you need to rise works every time w/any device, no trial and error, back and forth,......
I'm using the Andersen now but am always willing to try something that may be better,.... someone mentioned the stall mats and I might try that someday,..... but knowing how much to raise is certainly a benefit,....... I just stack boards, lego blocks, or stall mat pieces to the needed height, or drive forward on the Andersen a known distance,...... gets me level every time, 1st time,...........
fella10 is offline   Reply With Quote
Old 06-24-2016, 10:19 AM   #22
Restcure's Avatar
Originally Posted by OldCoot View Post
Only have 3" between the tires on my trailer and with a little modifying to the Andersons, they work great!
I'm not even sure we even have 3"... but the Andersen levelers can be trimmed to fit. Up to 4" off the front (between holes 1 and 2) and beveled to suit.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 06-24-2016, 10:27 AM   #23
Just trimmed the corner off mine.
Name:	Anderson Leveler corner.jpg
ID:	112009   Click image for larger version
Name:	Anderson levelers modified corners.jpg
ID:	112010   Click image for larger version
Name:	Anderson Leveler modified.JPG
Old 06-24-2016, 10:36 AM   #24
bpa098's Avatar
am i correct in saying you can pull onto or back onto these?
bpa098 is offline   Reply With Quote
Old 06-24-2016, 10:49 AM   #25
172av8r's Avatar
Yes. I usually pull onto them. Then when leaving, you can just drive off them!
2013 Rockwood Roo 23SS
2005 Toyota Tundra 4x4 4.7L V8
172av8r is offline   Reply With Quote
Old 06-24-2016, 10:52 AM   #26
bpa098's Avatar
after on place the wedge under it right?
I saw a video of the guy driving off the thickest end, trailer landed and bounced. Probably wont hurt anything but looked bad. could see that bounce popping open cabinets or something.
Old 06-24-2016, 10:54 AM   #27
Pickin' & Campin'
Do you have a single axle trailer or do you make your rear wheel "drive" over the front one when leaving?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-24-2016, 10:59 AM   #28
172av8r's Avatar
I have 2 axles. When you drive off them, the front leveler ends up in between the two tires and is easily removed.
See what I mean at 1:10 in this video
Old 06-24-2016, 11:12 AM   #29
What do you do when you need more than 4" of height?
Mr Havercamp is offline   Reply With Quote
Old 06-24-2016, 11:40 AM   #30
find another site, .... one time using a BAL Leveler on a single axle Casita, I did need to use the total rise, about 5", but that wasn't at a campground, it was in a back yard, but the BAL did it,....
leveling
