Old 06-24-2016, 01:08 PM   #31
Originally Posted by OldCoot View Post
Pretty easy mod with a table saw and a belt sander. Took all of 30 minutes and it is permanent.
Had to modify mine as well. Only a couple inches between wheels on our TT. I just cut off about an inch from the skinny end and they fit just fine now. Starts off at like 3/4" inch thick now. Figure if I have to level any less than that it's good enough and I leave it as is. lol
2013 Ram 1500 Laramie 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 06-24-2016, 01:16 PM   #32
172av8r's Avatar
If you only need to go up a little, just use one leveler. One inch rise on one leveler raises the camper 1/2 inch.
2013 Rockwood Roo 23SS
2005 Toyota Tundra 4x4 4.7L V8
172av8r is offline   Reply With Quote
Old 06-24-2016, 01:51 PM   #33
GreenImp's Avatar
Send a message via MSN to GreenImp
Originally Posted by 172av8r View Post
Yes. I usually pull onto them. Then when leaving, you can just drive off them!
The first time I used my Andersen Levelers I pulled forward over the big end as described. The rear one shot out the back clear into the forest (site surface was blacktop). I pulled forward very slow...which actually probably helped propel the leveler. Luckily no one and nothing got hit. I got brave and tried the method once again while leaving a gravel/dirt site...the forward leveler got jammed in between the tires (I've got one of those close fit setups that required trimming of the corners to fit). I still love my Andersen Levelers...I just don't "pull over" them any more!
Originally Posted by fella10 View Post
I'm using the Andersen now but am always willing to try something that may be better,.... someone mentioned the stall mats and I might try that someday
I used stall mat strips before switching to the Andersens. I liked them much better than boards and legos, but they are heavy...VERY heavy. The mat I cut into strips was 98lbs.
I still carry a few small pieces for when the trailer just needs an inch or less and for when the Andersens are not quite high enough. I also occasionally use them as padding for my knees when kneeling on gravel or wet surfaces.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 06-24-2016, 04:09 PM   #34
Originally Posted by bpa098 View Post
youroo..... i am usually very good and figuring out how something works but your system has me stumped. Pull past level on one, then slide the other in place and level out?
guys, believe me, i hate boards, REALLY want the andersons, but i am by no means rich lol. yes sure i have the money but try to stick to somewhat of a budget but have already gone way past this year on the camper mod/accessory budget.
but on a good note someone has messaged me with a used set of andersons at a great price so, this weekend will be boards (maybe just the old short ones) and soon i will have used andersons.
You are 100% correct,over pull then place other ramp behind release brake and they "Self level and Chock" 2 Moves,it don't get any easier! Anderson is 4 moves! Youroo!!
Old 06-24-2016, 04:16 PM   #35
Georgia Frog Rally 2018
aceinspp's Avatar
One move and I'm done. Why mess around. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-24-2016, 04:22 PM   #36
Anderson's only require you put them in front or behind the wheels and back until level and put the wedge in. Plus they are much lighter.
Old 06-24-2016, 04:26 PM   #37
(Dry Huunday)
DreiHunde's Avatar
Anderson's only require you put them behind the wheels and back until level and put the wedge in. Plus they are much lighter.
Yep. Never had to make 2 moves, let alone 4.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 06-24-2016, 09:44 PM   #38
Andersons each have (2) pcs. so that is (4) pcs. total for a dual axle unit! That is (4) Moves to place the Blocks and wedges! Like I stated our way is (2) moves Only (2) ramps! Youroo!! Also our ramps only weight 12# and only cost 39.00$
Old 06-24-2016, 10:39 PM   #39
gectisme's Avatar
Youroo,
Who makes those? I looked online for something like those ramps but only find ones that have steps in them.
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is online now   Reply With Quote
Old 06-25-2016, 05:10 AM   #40
Originally Posted by gectisme View Post
Youroo,
Magnum, Bennackurn,Ill. USA! Sold by Harbor freight! 6" lift /10" wide /supports 16,000 lbs! SKU# 67722 We only use the Ramps not the second section! Youroo!!
leveling
