Old 06-25-2016, 06:02 AM   #41
2x6's. And with the money you save get some X chalks.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
larryo is offline   Reply With Quote
Old 06-25-2016, 06:07 AM   #42
Originally Posted by youroo View Post
Andersons each have (2) pcs. so that is (4) pcs. total for a dual axle unit! That is (4) Moves to place the Blocks and wedges! Like I stated our way is (2) moves Only (2) ramps! Youroo!! Also our ramps only weight 12# and only cost 39.00$
Need to call Russell to borrow one of his spreaders.
Old 06-25-2016, 06:35 AM   #43
We "Level and Chock" at the same time! Don't have LONG boards and Stack Legoos! Youroo!!
I like the idea of this but I'm trying to figure something out. If you need say 4" of lift you pull forward on the front one until level? If so then the back wheel will remain on the ground. If you put the ramp behind it then wouldn't it only be acting as a chock?
Sent from my XT907 using Tapatalk
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 06-25-2016, 06:35 AM   #44
I can't help it that you have a Issue with MATH! Your method uses (4) pieces our way uses (2) Easy to count the Moves! Russell has Pumps not Spreaders! Youroo!!
youroo is online now   Reply With Quote
Old 06-25-2016, 06:37 AM   #45
I can't help it that you have a Issue with MATH! Your method uses (4) pcs. our way uses (2) Easy to count the Moves! Russell has Pumps not Spreaders! Youroo!!
Talking about truck/trailer moves, not pcs.
Old 06-25-2016, 06:43 AM   #46
No you are Up on 1 ramp the RV "Seeks it's own Level" when you release the Brake! It is then "Wedged between 2 Wedges"! In regards to needing 4" of lift,Andersons will not go that high,and you would need Lots of 2x? to acquire this also! Youroo!!
Old 06-25-2016, 06:50 AM   #47
If you need to raise one side 4" to be level, how far do you drive up one ramp to get the trailer to "settle" at the needed 4"?
Old 06-25-2016, 06:52 AM   #48
(Dry Huunday)
DreiHunde's Avatar
Yes your way is the greatest way ever.
Thats why everyone does it that way.....oh wait...
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 06-25-2016, 07:44 AM   #49
Originally Posted by Mr Havercamp View Post
What do you do when you need more than 4" of height?
Originally Posted by fella10 View Post
find another site, .... one time using a BAL Leveler on a single axle Casita, I did need to use the total rise, about 5", but that wasn't at a campground, it was in a back yard, but the BAL did it,....
I'm still wrestling with the above. Maybe "finding another site" works somewhere else where its flat but that option doesn't sound so good here in western/central PA .
We would be constantly searching for sites, 6" on one side is not uncommon and sometimes more is required. Then again we tend to camp at the less developed PA state parks and ACOE faciilites. The sites we choose are usually grass or leaves and hardly ever gravel or paving. I have even had to dig a few inches out under the opposite tires or under the front jack and A frame to get level once in a blue moon.
I'll stick with 2X10 and lynx blocks.
Mr Havercamp is offline   Reply With Quote
Old 06-25-2016, 08:04 AM   #50
boards and blocks will certainly work, they were the standard before any of the other gadgets came along,... if you have a single axle trailer, IMO the BAL Leveler is the best "gadget" on the market for leveling smaller trailers,.... and w/the BAL you can get 5 1/4" lift,... the links below show it at Amazon and a youtube video showing how it works, .... just my opinion, but I think its the best................
https://www.amazon.com/BAL-28050-Lig...eveler+campers
fella10 is offline   Reply With Quote
leveling
