Old 12-09-2018, 05:59 PM   #1
Leveling Pads
Just curious, has anybody ever tried the composite PVC board Home Depot has for leveling pads? It comes 3/4 thick 2X4 sheets for about $40. It would make 8 peices. I could use an easy method to connect them together. Not sure if it would be more durable then the plastic leveling pads normally sold.
Dietzldub is offline   Reply With Quote
Old 12-09-2018, 06:07 PM   #2
Isn't it heavier than wood? Just use dry 2x8s. I used to, but now prefer the plastic blocks that stack and lock together.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 12-09-2018, 06:08 PM   #3
Not very strong
loyda is offline   Reply With Quote
Old 12-09-2018, 07:17 PM   #4
I put a stall mat under my auxiliary tank and had enough left to make pads for six jacks. I use the snap together plastic pads to
spock123 is offline   Reply With Quote
Old 12-09-2018, 07:23 PM   #5
NMWildcat's Avatar
Just wait for a sale that applies to Lynx Leveling Blocks. Strong, light, easy to use and store. It was great to get rid of all the wood we used to carry.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 12-09-2018, 08:21 PM   #6
rmillermtsu's Avatar
I've used the Lynx blocks with the caps, pieces of 2x8's, and cut pieces of horse stall mat. I like the horse stall mats the best. What ever you use, I don't recommend using the Lynx blocks under your tongue pad because they are very slippery. Learned this the hard way.
2019 Chevy 3500 LTZ 4x4 DRW// Factory Gooseneck Prep// Andersen Ultimate Hitch
2018 Classic Super Lite 8528RKWS
2015 F250 6.2l Lariat 4x4 3.73's (Sold)
2016 Micro Lite 25DKS (sold)
rmillermtsu is offline   Reply With Quote
Old 12-09-2018, 09:10 PM   #7
Coach
Stick with 2x's and paint them if your concerned about longevity.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 12-09-2018, 10:58 PM   #8
NMWildcat's Avatar
Were your tires chocked properly? I've used them under landing gear a lot and never had any slippage. But then I've never used the caps either.
Old 12-09-2018, 11:08 PM   #9
The 2x4 sheet seems lighter then the same amount of wood. I saw that and was wondering if anybody tried it.
I used to use 2x8s, and now with my new TT, and TV combination Im just trying to keep the weight to a minimum. Ill end up going with the plastic blocks everybody uses.
Old 12-10-2018, 04:31 AM   #10
They were chocked on both sides, though not properly like I thought. I was lucky and was standing near the tongue when I noticed the tongue pad start to move very slowly across the top of the block cap. So I guess I learned two lessons that day. Make sure the wheels on both sides are chocked, and use a rubber mallet to set them (4 chocks in all) in both the front and rear of each tire. After leveling, I now use a set of Xchocks to keep the wheels from turning. The caps work ok under the tires and do somewhat protect the blocks from damage. I found that sometimes one layer of blocks was not enough, and two was too much. In that case the blocks combined with horse stall pads do the trick.Most sites we use these days are on concrete pads and are already pretty level.
leveling
