Old 07-09-2015, 08:52 AM   #11
avolnek's Avatar
Originally Posted by thetanu539 View Post
I guess I have been lucky then. I have used additional stabilizers (screw jacks) to accomplish this for about four years on two different units. I tend put two or three on each side down the frame and have not yet had an issue. Actually has made the TT pretty stable.
I will mention again I am more looking for better stabilization from the jacks. The factory installed ones are super cheap and wobble. This is another reason I put 4 - 6 additional stabilizers down the frame. I would love to cut that in half or to zero if I can find better jacks to stabilize.
You are on the right track contrary to the previous responses... I put 4 scissor jacks around ALL of my campers. I put one in front of and one rearward of the axles on both sides... I level side to side as you are wanting to do by an inch or so as well... all this is doing is unloading the suspension to help take the spring out of walking around... It has worked great for me in the past and is working great currently... I wouldn't recommend putting a ton of pressure really far back as mentioned this is when you can tweak the frame and cause issues with the doors... but i do not see any harm in having them near the axles...
infact, my previous trailer had a tire blow out one time and to get the tire off and back on (front axle) I put both scissor jacks on the rear side of the axles down and used the tongue jack to raise the front and wa la... I even went inside while it was like this to use the restroom and all doors seemed to function as needed...
As far as brand I had BAL. I didn't like their hand cranks but the jacks were very stout. I can't imagine you could go wrong with either...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 07-09-2015, 09:10 AM   #12
Old Ram Guy
Avenger61's Avatar
My TT has cheap scissor stabilizing jacks (factory installed) and I am looking to replace them with more sturdy leveling jacks for stability and the ability to get an inch or so of leveling ability out of new jacks. For those who have these type of jacks, either that you have installed or came with your unit, what band have you used that work well for you?
I have looked at a set of 24" BALs and 24" Huskys thus far. Any experience with these two brands and their quality?
I installed a pair of the Husky jacks just forward of the front wheels which gave me a greater ability to level the trailer. I was also trying to stop the bounce in the trailer when someone moved inside so I also installed a set of the Steadyfast stabilizers. That took care of almost all of my side to side movement and most of the forward to rear movement of the trailer. I recently started using the X-chock (just one) and now I have almost no forward to rear movement at all. That all runs into some expense but I was pretty determined to stop the bouncing trailer syndrome without screwing up my frame. This works for me and perhaps trying one of these solutions at a time will give you the stability and leveling capability your looking for. I would recommend the Husky jacks first. I'm a little skeptical of the weak frame discussions only because I've seen many trailers, including the one I have now, jacked up to grease bearings, change tires wheels etc and they simply jack it up on the frame. I have never seen any frame damaged from getting serviced this way. My opinion is that the factory installed jacks are much weaker than the frame and will give out before any frame damage occurs. I'm sure if you try to use jacks to level a trailer in large increments that you can damage not only the jacks but the frame too if you don't use common sense. The best way to level a trailer is to use leveling pads and the hitch, but when it comes to fine tuning I use the jacks I've installed. Good luck.
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
Old 07-09-2015, 06:43 PM   #13
It's a trailer and it's going to be giggle a bit . Lippert advises againt leveling by the frame. Trailer manufacturers advise against leveling by the frame. Yes, people do it and don't have any problems. And YOU may never have a problem. Hey, they advised me not to smoke and guess what.......after 30 years of smoking I got cancer! It's your trailer and you can do what you want after all, what do the manufacturers know?
larryo is offline   Reply With Quote
Old 08-10-2015, 11:33 AM   #14
Suspension on frame?
Placing jacks on either side of the axles (front and rear) would be lifting weight off the suspension which is always holding the frame anyway. Pictures I've seen here show much better placement of BAL "jacks" than at the ends of the frame where they can get knocked off or wrecked.
whatsupchuck is offline   Reply With Quote
Old 08-11-2015, 11:20 AM   #15
CWSWine's Avatar
I have a Lippert auto level system that uses jacks in the front and back to level the 5er. Check with you RV manufacture they can give your the info if you 5er can have the auto level system installed on it or not. Most modern TT & 5er you can install the auto level as aftermarket system but check with your manufacture first. Lippert says you can use auto level is limited to level 3 degrees left and right and ok if the one sides wheel come off the ground. I don't don't allow my wheels to loose contact with the ground but that just me.....
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
jacks, leveling
