Old 03-02-2014, 12:07 PM   #1
leveling travel trailer
whats the best way to level my travel trailer, its 36ft, 6600 lbs, it has electric supports on each corner, but I was told not to use them for lifting the camper.
Eddy G is offline   Reply With Quote
Old 03-02-2014, 12:42 PM   #2
Try this RV Technical Articles Page 1 - RV Basics .com Lots of good camper basics1
Glen & Lee
Cleveland, GA : Rochester, NY
2019 Primetime Sanibel 3851
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 03-02-2014, 12:43 PM   #3
Capt. Mike's Avatar
Level side to side by driving up on a 2" X 6" (or several 2X6's stacked on top of one another) on the low side. Level front to rear with your tongue jack. THEN put your electric stabilizer jacks down to stabilize the camper.
With a little practice, you'll get a feel for how many boards, how much height, you need under the low side, but check it with a level, too. You can also use those plastic Lynx leveling blocks, generally sold in sets of about 10. The stack together like Legos and make pulling up onto them pretty easy.
Good luck!
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 03-02-2014, 02:23 PM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
If you got a refrigerator then I would put a level in it and verify the other spot your using gives the same indication. refrigerators need to be level for smooth operation.
donanddona is offline   Reply With Quote
Old 03-02-2014, 02:28 PM   #5
camper1999's Avatar
Check out Anderson levelers. They work great.
Sent from my SPH-L720 using Forest River Forums mobile app
2011 GMC 2500HD Diesel
Old 03-02-2014, 02:43 PM   #6
I have the Andersen Levelers. They work very well. However, they are fairly long and on my TT they barely fit between the wheels.
Just something to consider. Otherwise they are great
Cherokee TT 304BH
LKB Camper is offline   Reply With Quote
Old 03-02-2014, 05:38 PM   #7
camper1999's Avatar
I cut an half inch off of mine still work great and fit great
Old 03-02-2014, 07:01 PM   #8
Good luck!
You can also add a bubble level on the front of the TT that has lines that represents an inch. You back where you want it, check the level pull up add the leveling blocks and back onto them. Installing a level on the side will help you with tongue leveling.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 03-03-2014, 04:56 PM   #9
I assume u trimmed off the thickest end ?
Cherokee TT 304BH
Old 03-03-2014, 05:16 PM   #10
bikendan's Avatar
i surprised that no one has mentioned Lynx Levelers yet. these, next to wooden boards, are the most popular items for leveling a RV.
Old 03-03-2014, 05:35 PM   #11
Capt. Mike's Avatar
Mike and Yvonne
Old 03-03-2014, 05:36 PM   #12
camper1999's Avatar
I actually trimmed off the tapered end. They still work great. I know others that did the same. We love ours one of the best things we bought
Old 03-03-2014, 05:44 PM   #13
bikendan's Avatar
sorry, Capt. Mike, i just read the first paragraph about the 2x6 boards!
leveling, trailer, travel, travel trailer
