Old 09-06-2017, 03:21 PM   #21
Georgia Rally Coordinator
aceinspp's Avatar
When I had two slides on one side with V-lite I would always put a 2x6 on the slide side as 99% of the time that side of camper always low. Next run stabilizer jacks down then put out slides. Almost level every time. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 09-06-2017, 07:51 PM   #22
My Rockwood has 2 slides on one side; 1 on the other. Even when on a gravel bed the two slides will cause that side to gradually settle and since that is the side the head of our bed is on, I set up that side high.
dsiegler is offline   Reply With Quote
Old 09-06-2017, 08:06 PM   #23
Retired
MainelyUS's Avatar
X2
One addition...we always put 2x8s under each wheel (except on a concrete pad) then add a 5/4 (1")x8 under the wheels on the slide side....works of us
Happy Trails
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is offline   Reply With Quote
Old 09-06-2017, 09:16 PM   #24
CaptnJohn's Avatar
Originally Posted by MainelyUS View Post
X2
Happy Trails
Less of this discussion will be seen as more new TTs with auto-level are sold. I have 3 slides on 1 side and one on the other side of a 43' 5er. I hit the auto-level button and put out the slides. Checking again the worst I've found is 0.1 degree out either or both directions.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 09-07-2017, 07:28 AM   #25
GrayghostUSA's Avatar
Originally Posted by Sunseeker24 View Post
There are a bunch of free ones, but this is the one we use.
https://play.google.com/store/apps/d...es.level&hl=en
hope this helps
Thanks, I use a similar app on my Windows Phone.
GrayghostUSA is offline   Reply With Quote
Old 09-07-2017, 05:15 PM   #26
Quote:Sunseeker24, what is the name of the app you use?
I've used "ez-Level" on my iPhone
Work great
bajamike1 is offline   Reply With Quote
Old 09-07-2017, 08:56 PM   #27
I think I like the idea of the Anderson Camper Leveler. . If it works the way it does in the video I see leveling as they show, running out the slide and adjusting without pulling off of the leveling chocks. It can't be that easy.......
Old 09-12-2017, 02:47 PM   #28
One word of caution, as I own a set of these leveling blocks. This may be a n ok plan if leveling 1 to 3 inches, but rolling over that a 4th inch allows the trailer to drop 4 inches very quickly. Would never want that bounce to happen with the slides out.
BigGuy87 is offline   Reply With Quote
Old 09-12-2017, 03:23 PM   #29
johngoat2002's Avatar
Leveling with 2 slides on same side
I have owned two sets of these levelers. They work really well for three or four times, but I've had both of mine break when rolling off of them. I thought maybe the first time could be my fault so I gave them a try again. I've reverted back to the good ole blocks after the second one broke.
johngoat2002 is offline   Reply With Quote
Old 09-14-2017, 05:58 AM   #30
We have a 2017 Salem 326RL which is a triple slide unit. The two slides which extend the furthest, approx 3-0' are both on the same side which makes that side of the trailer much heavier. With the 4 point stabilizer system, the heavy side will settle about 1/2 bubble on my stick on level attached to front of the trailer. I have learned to use my Andersen levelers and raise the heavy side 1/2 bubble high FIRST, then put down stabilizers and extend the slides. This has worked for us many times on different types of surfaces without problems. I would not move your trailer with the slides extended. Too many alignment issues can happen.
On smaller campers with individual scissors jacks, one can sometimes take a little more weight off the springs to raise the low side slightly, but this is not possible with the 4-point system.
2017 Salem Hemisphere 326RL
2009 Chevy Silveraldo 2500
meandmylabs is offline   Reply With Quote
Old 09-14-2017, 06:54 AM   #31
ben31's Avatar
Originally Posted by mjones12 View Post
I use one called Bubble Level.
Another app is Clinometer. It has both a inclination and bubble level. The inclination helps set up satellite dishes and the bubble level does just that. I also use the clinometer for rough carpentry to get cut angles.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
leveling, slide
