10-22-2016, 11:18 AM
Racin
LevelMatePro
LevelMatePro is for sale again on Amazon
2014 coachmen clipper 15RB
2000 ford f-150 super cab 4.2 6 cyl
10-26-2016, 03:13 PM
Must have been a daily special because it's showing at $139.99 today.
Happiness is just a ride away!
10-26-2016, 07:04 PM
Has anyone used it? I just saw this post and looked it up. How does it it work exactly? Thanks
2016 Ram 2500 Cummins
2017 Heritage Glen 312QBUD
10-26-2016, 11:14 PM
I'm really liking it, to install it you level the rv then attach a small sending unit. I put mine in a front cupboard, it uses a common CR 2032 watch battery. After downloading the app you choose trailer or motorhome and enter the width and wheelbase.
Once installed you can see the inches (or fraction of an inch) of levelling blocks needed under each wheel. Pretty handy while your parking your rig to find the best spot without leaving your seat and then pulling out the right amount of blocks the first time.
I've been in some pretty rough sites on fishing trips and I find it pretty handy. I'm not a pro at translating my bubble level into inches required so I find it pretty handy.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
10-27-2016, 04:39 AM
Insert witty title here
I have a free app on my phone that does the same thing.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
10-27-2016, 05:05 AM
Care to share?
10-27-2016, 08:03 AM
Not sure how it could, this app does not use the phone for a level it connects to the module that is the level.
Brian
10-27-2016, 08:05 AM
Will it account for the two slides on one side that make it lean that way tremendously. That's my biggest complaint about setting up, trying to get it the correct amount of unlevel so when the slides go out it's level.
10-27-2016, 08:09 AM
That seems odd to me. Once yo u are level and landing gear is deployed, level shouldn't really change from the slides going out. At this point your suspension should be out of the equation, no?
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
10-27-2016, 08:24 AM
Although relying on an expected amount of lean to bring you to level is not always reliable, you certainly could configure this device to do that.
All you do is mount the device on a wall, as close to level as possible, then reset it to level. To do what you want, you would just set it to level when your camper is leaning. Meaning, have your camper leaning, with the slides in, then reset the device to level. This would allow you to set your camper to the same lean every time. Not sure how reliably your camper leans when the slide goes out though.
10-27-2016, 08:26 AM
I put my phone on the frame and it tells me how far off level and in which direction. I know instantly how many leveling blocks I need on which side.
10-27-2016, 09:46 AM
Again...please share!
10-27-2016, 09:54 AM
If you have an Iphone, go to the compass app and scroll right, it turns into a level!!
2019 Silverado 1500
No camper, currently
10-27-2016, 09:58 AM
Thanx for the reply! I am currently using android...will search for compass app.
10-27-2016, 10:00 AM
The two best android level apps I've found (and use) are RIDGID digital level and Bubble Level.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-27-2016, 10:31 AM
The app is called Clinometer.
10-27-2016, 11:31 AM
Installed the Ridgid app...Thanx!
10-27-2016, 02:19 PM
Here's a pic of the leveling screen for a motorhome. You can check it from the driver's seat or anywhere outside.
Brian
10-27-2016, 02:37 PM
That is AWESOME!!! I had no idea. Thanks for the info! Works great!
2017.5 Rockwood Ultra Lite 2905WS (all the options)
New TV- 2017 Ram 3500 SRW Sport 4X4
Old TV- 2007 Dodge Ram 1500 Sport (Hemi)- towing vehicle
