Old 04-02-2008, 11:51 PM   #1
Canadian member
northernburb's Avatar
Angry Living in Colder Climates
A spot on the news tonight regarding the linoleum flooring used in Travel Trailers of late. It appears that manufacturers are only gluing the linoleum down on the outer edges and around vents on Travel Trailers, and not doing the whole floor area. In colder climates, like here in Edmonton, this is causing the linoleum to split and curl throughout the rig. A major dealer here had a bunch of their New trailers suffer this fault over the winter. Of course the manufacturers aren't too worried if the Trailer is over the warranty period, as well it seems that Extended Warranty companies, are not entertaining claims either. I couldn't believe my eyes when I saw that on the news because I had just got back from retrieving something from mine in storage and low and behold my lino has cracked right down the middle and just as the news story explained there is no glue under the middle just around the edges. I noticed that the vinyl flooring has a 5 year warranty but I suspect it would be covered under the 1year construction and workmanship warranty
ME AND THE WIFE AND DOG
2012 gmc 1500 Sierra slt
2005 SV 291 Surveyor
northernburb is offline   Reply With Quote
Old 04-03-2008, 12:13 AM   #2
That is disappointing! Hopefully the manufacturers will take notice of this and change the way they install linoleum flooring. Would be nice to see them step up to the plate and cover poor manufacturing procedures. Car manufactures seem to do it from time to time. Hopefully I will avoid that damage as I have always kept a heater in my trailer throughout the winter keeping the temp above freezing. Best of luck on your repair.
OREGONCAMPER
2008 Rockwood 8317SS - 2010 F150
2013 Camping Days: 22
2012 89 2011 50 2010 61
OregonCamper's Pics click here
OregonCamper is offline   Reply With Quote
Old 04-03-2008, 07:45 AM   #3
RJW
That stinks, good luck on getting the manufacturer to cover replacement.
Regards, RJW
2006 Expedition 4x4 w/HD tow package
5.4L 4 speed auto w/OD 3.73
tow rated 8200
2008 Cougar XLite 30FKS
gvwr 7800
Alvarado TX
RJW is offline   Reply With Quote
Old 04-03-2008, 10:44 AM   #4
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
My brother-in-laws SALEM trailer did just this last winter. (ND)
His was out of warranty by a couple years.
It's not uncommon with travel trailers...I may go out and check on mine today. I'm more worried about mice!
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 01-15-2009, 04:14 PM   #5
Has anyone had any luck with claims to this matter after the warranty has expired? Any tricks on repairing this without replacing the whole floor? My Sandpiper`s floor just cracked down the middle last week when it hit -40 here.
redrum is offline   Reply With Quote
Old 01-18-2009, 08:30 PM   #6
The Jolly Mon
NDJollyMon's Avatar
It's been that cold here too. I'm worried about mine this year. I hope it's ok.
Haven't heard of any warranty claims....
Pete (Jolly Mon)
Old 01-18-2009, 11:21 PM   #7
NWJeeper's Avatar
Well on the bright side look at it as a chance to lay down some of the laminate wood flooring over it. The linoleum serves as the underlayment you would usually use. Just install the flooring right over the top. I did this in our old Fleetwood motorhome we used to own. I ripped out all the carpet left the lino. and put down the underlayment where the carpet used to be then layed the floor down. was a easy job that made the rig look a lot better as well as being easer to keep clean.
Ed & Wendy
www.nwjeepn.com
Old 01-19-2009, 10:20 AM   #8
STATIC's Avatar
That's crazy now I know whats happening when I vacumm the floor in my rockwood, it's like the vacumm is stuck to the floor...
2008 Tundra Crewmax
2006 21ss Rockwood Roo
2008 Hardknock
STATIC is offline   Reply With Quote
Old 02-18-2009, 10:41 PM   #9
Itching to camp in 2009
I had that problem, I bought my trailer last spring and the floor was totally destroyed. I was lucky in that I took delivery after the fact and FR and the dealer replaced the floor (glued everywhere) upon delivery. Our dealer said they has over 40 new units with floors that had to be replaced. They also said it only happens when the temp goes below -40 C/F.
Sorry to hear about the extra cost to some of you that were not so lucky to have it covered under warranty.
Go OILERS Go!
Bulmzie4 is offline   Reply With Quote
Old 05-21-2009, 12:20 AM   #10
jeffnjen1's Avatar
We picked our TT up from storage this week and found our floor had done the same thing. We are a couple of months past our 1 yr. warranty. The DH called the dealer, they requested pictures of the floor and will see what they can do to get it covered. If they don't cover it we will be looking into putting down laminate ourselves. If any one has any suggestions on how to handle this please let us know. Thanks!
Jeff, Jennifer and 1 active 3 yr old boy
2002 Ford F-150 Super Crew
2007 Surveyor SV291
Minnesota
Our photos: http://www.forestriverforums.com/Pho...00&ppuser=1363
jeffnjen1 is offline   Reply With Quote
