Old 07-23-2012, 06:15 AM   #1
Looking at used truck with 5th wheel hitch removed
Looking at a used 3/4 ton TV low milage price is right etc. I found out it had a 5th wheel that has been removed. There is a bedliner covering everything so its not visible. Does anybody know if the holes left behind in the frame rails and bedfloor could pose any issues? Its on a dealer lor about 2 hours away I did some research and found the original owner and found this out. He said he towed about 3K miles total with his camper.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 07-23-2012, 06:23 AM   #2
KyDan's Avatar
My guess is no problems. Many folks have 5th wheel hitches and they don't have
problems so why would you think the holes would be a problem?
2nd, many of those with 5th wheel trailers used to have regular trailers like you and me.
One day you'll want a bigger trailer and your wife will start salivating over those nice
big 5th wheels and you'll have the truck with the holes already drilled!!
My 2
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-23-2012, 07:38 AM   #3
TURBS's Avatar
There are water drain holes in your bed anyway.
But I would remove bedliner and spray some rust proofing in and around holes.
You can buy aerosol cans at any parts store.
Old 07-23-2012, 06:09 PM   #4
I was worried about the holes drilled into the frame rails and such compromising the integrity of the trucks frame. They will be empty holes now but I guess I could seal them up. It's a real nice 3/4 ton truck with low milage and in great condition. Guess i'll call the dealership back in the AM.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 07-23-2012, 06:45 PM   #5
Md Jeff's Avatar
Depends on the truck and brand of frame mounts; I have a Dodge 2500HD and my frame brackets are no drill brackets, they are two piece brackets that bolt around the frame instead of to it.
Md Jeff is offline   Reply With Quote
Old 07-23-2012, 07:01 PM   #6
It's an 06 Ram Mega cab 2500 I think it had a side winder if I remember correctly
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 07-23-2012, 08:11 PM   #7
Md Jeff's Avatar
Mines a '05 QC and the '06 would probably require the same brackets,not sure how the brands play into it. Poke your head under either in front of or right behind the rear axle and have a look/see. Should easy enough to spot, it will have bolts running under the frame,through the bracket.
Old 07-23-2012, 08:49 PM   #8
Taranwanderer's Avatar
Call the original owner back, find out what kind of hitch he had, and buy the same one, re-install it in the same holes, spray paint/rustproof the crap out of everything you can, and you're ready for whatever life throws at you!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 07-23-2012, 09:10 PM   #9
Sounds great but I have a Travel Trailer lol
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 07-23-2012, 09:14 PM   #10
TURBS's Avatar
I wouldn't be worried about the blank holes.
And if you are really worried about than make a strap and mark and drill holes in the strap and bolt from hole to hole.
good luck in your pending purchase.
Ron
5th wheel
