Old 11-02-2014, 09:00 AM   #1
Loud frig in new RV
We are currently on our maiden voyage with our new Rockwood 5th wheel. Making sure everything is working. So far it is great, just a few missing screws in the screen door that we fixed. However, the refrigerator is very loud. Constant loud humming, is this normal?
snyder85086 is offline   Reply With Quote
Old 11-02-2014, 09:50 AM   #2
Average Joe
MrJoe's Avatar
Ours is loud, too. It's actually the cooling fans most likely. Many folks replace them with better, quieter fans.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 11-02-2014, 10:03 AM   #3
It's probably a converter fan located next to the refrigerator.
Ham_Bone is offline   Reply With Quote
Old 11-02-2014, 10:11 AM   #4
Witch Doctor's Avatar
Which model do you have both post could be correct. And welcome to the Rockwood Family....
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-04-2014, 05:14 PM   #5
We have a 2015 signature 8289WS & love it
Old 11-04-2014, 06:42 PM   #6
If you have that your unit converter is next to the door as you enter, so then I would say that you are hearing the fan in the upper part of the slide behind the air outlet for the refer. The fan shouldn't be running all the time just when the coil gets hot, the fan is directly below that top opening on the outside of the slide. I changed mine out and also added a second fan next to it. More air quicker coiling it's runs by a stat in the coil blade on the bottom left of the coil fin. Under warranty have them replace it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-04-2014, 07:19 PM   #7
Bakka323's Avatar
My buddy had the same issue. He found out that his frig wasn't breathing properly. His frig is in the slide out resulting in the venting being placed on the wall of the slide out rather than on the top.
2006 Nissan Xterra 4X4
2013 Surveyor SP-189 Cadet
Bakka323 is offline   Reply With Quote
Old 11-04-2014, 07:26 PM   #8
Bakka323's Avatar
....continued.... Both of his vents are painted like a car ...and to prevent paint going into the vent, FR taped the backside of vent to prevent paint from going inside. However FR forgot to remove the tape which can only be found if the vent is removed. After the removal of the tape, the frig started to breath better and make less noise. He also added a computer fan to help cool the frig.
