10-29-2014, 02:03 PM
Low point drains
I found these valves at Lowes and added them to my low point drains.
2006 Chevy Silverado 2500HD
2012 Rockwood 2902SS
10-29-2014, 02:24 PM
Those are nice. I lucked out and mine came with cheep plastic valves that I'm sure won't last long. You shouldn't ever have a problem with those ball valves.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-29-2014, 08:27 PM
You know, you can't beat the ideas and gadgets we learn of on these forums..thank you!
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
10-29-2014, 08:36 PM
I'll remember these when my cheep plastic one need replacing.
10-29-2014, 08:48 PM
Nice. I just winterized our trailer so will look at doing that for next year.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
10-29-2014, 09:25 PM
Is there any risk of the weight of the handle opening the valve when your bouncing down the road?
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
10-30-2014, 06:13 AM
I like this idea...I wonder the same thing that Indybp57 wonders ^^^^^
10-30-2014, 06:46 AM
Plain Old Member
We had those originally, then went with the really small stop valves mainly due to weight. While your putting valves, might as well add them to all sinks and toilet.
Sent by ME
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
10-30-2014, 06:51 AM
Plain Old Member
Low point drains
This was under our silverback going to the outdoor kitchen. Made an aluminum bracket to minimize any movement and of course insulated this. This was originally a dumb design by cedar creek. Heated enclosed tanks and plumbing, except this which originally was all hard piped with no valves or insulation. Did this to isolate outdoor kitchen in winter and be able to isolate / drain rear half of coach.
Sent by ME
10-30-2014, 01:12 PM
I just put one of these on my cold water low point drain so i could hook a hose to it .useful when cleaning the deck,watering plants etc. (i'm on a seasonal site)
2008 rockwood signature ultra lite 8315SS[SIGPIC]
10-30-2014, 02:10 PM
I moved my valves to the heated basement. Now no water is in the low point drains that are exposed to the elements. Mine froze last year in Florida of all places and expanded the 90 degree fitting and water was dipping into my underbelly. So now I leave the exposed drains empty. If I need to open them I do it from the valve in the heated basement. That's the weak point. unless you insulate the exposed lines to the elements.
Coachmen M/H
Concord
2018 / 300 DSC
