Old 11-12-2010, 08:07 AM   #1
Angry Low Point Drains on Rockwood Ultralite 2702ss??
I have a rockwood 2702ss, I am wondering where or is there a low water point drain for this or similar TT?
It was delivered winterized but I would like to know where this is?
I had a pop up that had two valves under the sink that had to be pull up to have city water connected and pushed down to drain after unhooking water source.
Is there a similar procedure on this trailer?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 11-12-2010, 08:13 AM   #2
I have the 8313 and my low point drains are under the rear on the curb side. I have two caps to remove to drain. Hope this helps
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 11-12-2010, 08:14 AM   #3
thanks Bill
Old 11-12-2010, 12:10 PM   #4
tomjsas's Avatar
on my 2501ss, they are located on the door side below the bathroom sinks. have to get down and look up. they have easy pull T like valves on the end.
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 11-12-2010, 12:17 PM   #5
tomjsas's Avatar
Note: This post was moved from a parallel thread.
So...this is similar to your post in another spot - might want to just post in one spot. I posted a reply there. With my 2501ss, the low point drains are on the door side in the rear below the bathroom sink area. These are used to drain out most of the water prior to winterization. For using the connection to city water, they have no connection. When you attach your fresh water hose from the spigot to the city water connection on the trailer, the pressure opens a check valve that then shuts of water coming from the water pump supply (don't need water pump on when hooked to city water) and allows the city water to flow through the system. If you are using the fresh water tank on the trailer, there of course is a separate fill for that and its own drain valve that is usually located somewhere below the fill. Hope that helps.
Tom
Old 11-12-2010, 01:53 PM   #6
sorry for the repeat, I wasn't getting any answeres so I thought I needed to repost. Thanks for the great answers this am!!
Old 11-12-2010, 02:05 PM   #7
Low point drains on our 2605S are under the bath tub. We actually had to call Forest River and ask them where they were on our model.
Momma Tac is offline   Reply With Quote
Old 11-12-2010, 02:06 PM   #8
MtnGuy's Avatar
Not a problem.
If you aren't getting answers during a certain time period, just do a short post like "other ideas ??" or something, and it will put this thread back on top of the category, and also will show if someone just uses the "New Post" button like I do.
You might just have to do a trip under the camper and check to see where those puppies are.
Old 11-12-2010, 02:31 PM   #9
On my 2601SS their under the couch. this should be the same as your 2701SS Easy to get to with the slide out but can be done with it in. If not look under the camper for 2 lines coming out
2007Rockwood2601 is offline   Reply With Quote
Old 11-12-2010, 09:28 PM   #10
wro28
On my 2604 they are right in front of the dump valve. You have to look from underneath as the skirting will block their view.
Bill
Langhorne, PA
2008 Toyota Tundra
2011 Rockwood 2604SS
wro28 is offline   Reply With Quote
ultralite
