Old 11-16-2008, 03:48 PM   #11
KyDan's Avatar
There is always the possibility they forgot to install them in the occasional trailer!
Old 11-17-2008, 10:22 PM   #12
Bluebird,
Thanks for your posting. I did say I had followed the piping and looked in all accessible areas for low-point drain(s). It certainly never occurred to me that anyone would put them UNDER the bathtub. Naturally, our dealer told us nothing .... there's a surprise!!!!!
Anyhow .... our trailer is winterized and in storage now, but I'll definitely have a look under the tub in the Spring. Thanks again.
John
John is offline   Reply With Quote
Old 11-18-2008, 08:30 AM   #13
I have a 2006 Puma 26fbss and could not find low points drains, carried it to a dealer and he could not find them either. Does anyone know if Puma just doesn't use them or is it my model or we just haven't found them? Thanks
Danny is offline   Reply With Quote
Old 11-19-2008, 12:54 AM   #14
Once i tried to find out where they are in my trailer. It took me almost 1hr to find out them.
Please dont give up they are there somewhere.
Technosurfer is offline   Reply With Quote
Old 11-19-2008, 12:54 AM   #15
2009 cherokee 39 bs
Low points in passenger side front wheel well area.
plumech is offline   Reply With Quote
Old 11-19-2008, 03:37 PM   #16
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
John,
I would add that, if they are indeed under your bathtub as they are in mine, then there should be about an 8" square access panel on your tub. It will be at floor level and is held in place with 4 screws. Mine is at the bottom corner where the tub meets that bathroom door. Good hunting!
Originally Posted by John View Post
Bluebird,
John
dimurrrw is offline   Reply With Quote
Old 11-20-2008, 12:21 AM   #17
Ray
Ray's Avatar
I found the drains in my 26RLS under the sink in the kitchen. The cold water drain is behind the panel inside the door, directly below the stove. You might be able to reach this one without removing the panel inside the door, but since it is easily removed, this will make access to it easier.
The hot water drain is accessible by removing the bottom drawer, and reaching around to your left for the drain. It is easily visible when this drawer is removed. Both drains stick out under the trailer behind the wheels on the street side of the unit, and can be very hard to see. The drain valves on my particular unit are the type that you pull up to open and push back down to close.
Thanks to all of you that replied to my original question, the information given was very helpful in allowing me to locate these drains.
2011 Ram 1500 Laramie Longhorn, 5.7 Hemi, 3:92 differential
Tow Package W/Integrated TT Brake Controller
2015 Open Range LT274 RLS
Ray is offline   Reply With Quote
Old 11-20-2008, 07:07 AM   #18
AKA Bluebird
dimurrrw's Avatar
Old 11-20-2008, 07:23 AM   #19
aintgotnun is offline   Reply With Quote
Old 11-20-2008, 07:52 AM   #20
Head Rambler
I really glad you found them. I'm even more glad you came back and let us know where you found them.
A friend has the pull-up/push-down type but they were easy to find. They're under the vanity.
Gotta go campin!
