Old 07-02-2015, 11:53 PM   #11
KMANUEL74's Avatar
I converted my Coleman Road Trip to use the quick connect on TT. I bought three items to do this what nbenn3 did and it cost about $40. Here is a video on how it is done:
The first is a 90 degree elbow:
Robot Check
Next is the Quick Connect:
Robot Check
The the hose:
Robot Check
KMANUEL74 is offline   Reply With Quote
Old 07-03-2015, 01:34 AM   #12
Is your gas flow valve part of the regulator? If so,when you remove the regulator you will need to put something in line to control the flow.
larryo is offline   Reply With Quote
Old 07-03-2015, 05:03 AM   #13
Dumb question, if installed this way without regulator does this mean you can't control flame on grill? If you can't, on a scale of 1-10 (10 being highest) what size flame do you get?
2015 274 RK LIMITED <'{{{{><
captainperry is offline   Reply With Quote
Old 07-03-2015, 06:04 AM   #14
KMANUEL74's Avatar
I have not used it much, but it looks the same. The good thing with this conversion is if you dont like it, you can convert it back.
Old 07-03-2015, 09:32 AM   #15
No, it means the grill has its own regulator built in. The flame is controlled by the gas valve on both systems.
If you hook up a grill with two regulators, one on tank and one on grill, the gas pressure drops to low and you can't hardly get any flame.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 07-03-2015, 10:26 AM   #16
mike.t's Avatar
What oldtool said. You can not have 2 regulators
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-03-2015, 10:27 AM   #17
mike.t's Avatar
No. The regulator is on the RV. Unless your talking about the min/max knob then you would have no way to turn it on/off.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 07-03-2015, 11:24 AM   #18
nbenn3's Avatar
All this does is make a really long extension from the propane tanks. You still have the regulator on the tanks themselves. You're just eliminating the one attached to the grill. I've used it like this for 3 years and it works great and much better than toting bottles around.
nbenn3 is offline   Reply With Quote
