Old 07-01-2015, 09:33 PM   #1
Newbie Extrodinaires
RossandLindsay's Avatar
LP Quick Connect to Coleman
I'm looking for some info about connecting my TT's LP via a quick connect to other propane accessories that do not have the quick connect parts. What fittings do I need to, say, connect my back porch grill to the campers supply? What about a Coleman style disposable propane can set up?
Ross and Lindsay
2015 FOREST RIVER - ROCKWOOD MINI LITE 2306
2006 Ford F-150 Super Cab, 5.4L V8
RossandLindsay is offline   Reply With Quote
Old 07-01-2015, 09:40 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
You could start with something like this.
http://www.amazon.com/Camco-59123-Pr...YCT1XD77G17CT1
Remember the propane on your RV has a regulator already. You might have to remove the regulator from your grill.
donanddona is offline   Reply With Quote
Old 07-02-2015, 08:06 AM   #3
That is exactly what I'm looking for!! I wish it didn't cost 60 bucks, but, after the trouble I've had finding something for this issue, I'll take it!
Thank you!!!
Ross and Lindsay
Old 07-02-2015, 08:47 AM   #4
jeff64's Avatar
Thank you!!!
Try the camco #57282 10', go to hardware store get a brass hex bushing 1/8 NPTF x 1/4 NPTF. Take female quick disconnect off the hose. Carefully remove pressure regulator from grill. ( I did this on a Weber Q, should be about the same deal) Using teflon tape, wrap the connections. If, down the road you might want to go back to the canned fuel, get a brass 1/8NPTM x 1/4 NPTM nipple and put the regulator back together with the female quick connector you removed and you should be good to go to reconnect bottle/regulator assy.
Old 07-02-2015, 09:37 AM   #5
Again, perfect. thank you for the descriptive part names and numbers. I feel much better equipped to deal with this now.
Ross and Lindsay
Old 07-02-2015, 11:19 AM   #6
mike.t's Avatar
You have to remove the regulator from the Coleman stove if you want to tap in to your RV propane. I think the Camco item goes before the regulator if so your Coleman will work. Sometimes there is a room problem with these
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-02-2015, 01:12 PM   #7
nbenn3's Avatar
Name:	ImageUploadedByForest River Forums1435860733.912277.jpg
This is what I did for my Coleman roadmate which is what Jeff64 is describing I believe and it works perfectly and only cost about 10 bucks or so.
nbenn3 is offline   Reply With Quote
Old 07-02-2015, 01:16 PM   #8
LP quick connect for Coleman
Try Lowes in the BBQ dept. Prices are pretty reasonable.
wildwoodtraveler is offline   Reply With Quote
Old 07-02-2015, 02:20 PM   #9
mike.t's Avatar
Originally Posted by nbenn3 View Post
Attachment 81904
Looks like you removed the regulator. Now tap in to the RVs propane line (after the regulator) get a male and female quick disconnects and start cooking.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 07-02-2015, 11:31 PM   #10
Use the yellow Teflon tape made for gas, the white is for water lines.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
