Old 04-08-2016, 05:24 PM   #1
rmac04401's Avatar
Max air vent cover
Has any one installed a max air regular vent cover over a fantastic fan? Standard vent cover is 00-933066.
Name:	ImageUploadedByForest River Forums1460153739.324973.jpg
The manufacture said in instructions one I got this it not recommended for high powered fans. I looked at the model 00-945003 should be the one I need. Of course that one is 3 times as much. Just wondering if this is just a marketing scheme to get more money. The dimensions between the two are basically the same by the looks. Maybe 1 inch shorter.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 04-08-2016, 05:56 PM   #2
HookupAndGo's Avatar
I mounted those on both of my TT prior to my Class A. The vent opens up enough and the Fans really pull a lot of air, even on low. I was more than happy with it.
So, I would say absolutely -- and if I had an FF on my current RV, I'd use the same thing, although I used the wider Maxx Air I think on my current unit. But, the Maxx Air is the same height and all.
If you plan on running on any just the lower couple speeds, I would say your would be fine.
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
HookupAndGo is offline   Reply With Quote
Old 04-08-2016, 06:47 PM   #3
TURBS's Avatar
Imo I'd get the maxx air fan mate.
Super simple to install.
I've got two powered vent fans with these on.
http://m.campingworld.com/browse/sku...H6IaApEo8P8HAQ
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-08-2016, 06:48 PM   #4
TURBS's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-08-2016, 08:19 PM   #5
WFD
What you are showing there is the Max Aire 1,,, the post further down by Turbs is the Max Aire 11. I have installed both over Fantastic Fans. The Max Aire is a bit more money but not alot, and they are easier to flip for cleaning, as you just need to pull a cotter pin whereas on the Maxair 1 you will need to use a wrench or socket. They are also shaped a bit different so as to allow more air flow. Some will tell you that they restrict air too much for Fantastic Fans...your fans will still move more than enough air, even on a lower setting, not to worry.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-08-2016, 08:23 PM   #6
TURBS's Avatar
Correction I'm showing a max air fan mate in the pic above. ⬇️⬇️⬇️this is a max air II
Shown with a maxx air I
Old 04-08-2016, 09:06 PM   #7
HONDAMAN174's Avatar
I see them at $42 on Amazon- think I paid 36 so I don't see the x3 part.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 04-08-2016, 09:18 PM   #8
rmac04401's Avatar
Max air vent cover
The one referenced in the original post on Amazon (945003) is $90 dollars. There have been many models discussed on this thread. Yes the 933072 is $41.72 on Amazon but that is not the one that maxxair recommended and was posted in original post. That is also not the one turbs displayed (955002).. 955001 is white. There are many variations of the MaxxAire vent cover.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 04-08-2016, 09:34 PM   #9
TURBS's Avatar
Max air vent cover
Maxx air
Maxx air II
maxx air fan mate
Maxx air 950
Maxx air cyclone?
Maxx air 850
Maxx fan
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-08-2016, 09:40 PM   #10
Retusps's Avatar
Black MaxxAir FanMate EZClip Vent Cover - Maxxair 00-955002 - Vents - Camping World
2008 2500hd Duramax
2015 Columbus 320RS
Turbs, does the MaxAir fan mate move more air than the MaxAir II ?
No matter where you go, there you are!
2006 GMC Sierra CC 1500 Z71
2014 Palomino Solaire Eclipse 297rlds
Husky Centerline w/d hitch
Retusps is offline   Reply With Quote
cover, vent
