Old 09-23-2010, 01:16 PM   #11
drvol's Avatar
I was looking into this as well...found what I wanted at RV Wholesalers but waited to order until I got home last night to check up on the roof to see how installation would go. I found out that the vents themselves...or atleast the sil around the vents are covered very heavily with the sealer FR applies upon manufacturing. I was under the impression that these covers were bolted to the frame/sil that goes around the vent. There is no way I can attach these covers without removing the sealer/caulking or I have to drill into the roof around the vents. I have a 2011 Shamrock 233s. Is this something new or am I missing the intent to install?
drvol is offline   Reply With Quote
Old 09-23-2010, 01:28 PM   #12
shineysideup's Avatar
The covers are bolted with 8-32's or something close to that size. Don't remove any caulking around the vent. The caulk is soft, I pushed the mount brackets into the caulk a bit and then drilled holes in the side of the vent cover (not the roof). The vents don't have to sit tight on the roof (mine are off about a 1/4" - to me this is fine, the vents won't rub on the rubber roof). Get the maxxair 2's you can open and clean underneath very easily.
My two cents....
shineysideup is offline   Reply With Quote
Old 09-23-2010, 01:37 PM   #13
3 Happy Campers's Avatar
X2 on what shineysideup said
I actually just installed several on my new 5er.
They take about 10 minutes each.
I decided to use pop-rivets instead of the supplied screw/bolts.
You never want to puncture the roof membrane unless absolutely necessary.
3 Happy Campers is offline   Reply With Quote
Old 09-23-2010, 02:09 PM   #14
drvol's Avatar
Thanks for the info...so they bolt to the sides of the vent frame in a horizontal position rather a vertical attachment...gotcha.
Old 09-23-2010, 02:19 PM   #15
Check out this web page. It has a quick installation video.
MaxxAirII Install
phoneman06 is offline   Reply With Quote
Old 09-23-2010, 02:26 PM   #16
frankm's Avatar
Here is the link to the MaxxAir II installation. http://www.maxxair.com/doc_download/...tallation.html
frankm is offline   Reply With Quote
Old 09-23-2010, 02:36 PM   #17
I am not sure what color Black or white anyone have the smoke color?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 09-23-2010, 02:46 PM   #18
The Old Man
Willis's Avatar
When pre-drilling holes into the frame for the brackets, I recommend putting a piece of paper or thin cardboard on the caulk to protect it (i.e., between power drill and caulk). Otherwise the spinning chuck will do a job on the caulk...don't ask how I know that.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 09-23-2010, 02:47 PM   #19
I prefer white... it doesn't pick up the heat from the sun in the summer as would black or smoke colour...
Old 09-23-2010, 02:49 PM   #20
Make that two pieces of cardboard... another one for the tools! I took my shoes off also, just in case there was something stuck in the soles...
