06-01-2016, 07:19 AM
Maxxis Tires
Well I used to be a GY Marathon Man all the way, but after 3 years of buying new 225/75/ R15 to replace my Trail Express C rated I had 2 belts just brake and caused many problems. I defended that brand till I was blue in the face, but not no more. I had to replace my tires with Maxxis this time. Same size "D" rated 65 PSI. My question and I hope someone can answer is that Maxxis is calling these "HIGH SPEED ST" I asked the dealer and also tried to fine the speed rateing, the dealer couldn't and also there is nothing on Maxxis web site. I was always told max speed for a ST is 65 miles per hour, so what does High Speed mean? Thanks for your help... The new tires are Maxxis 8008 D rated. 8 ply
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 07:47 AM
Tire Tech Information - Trailer Tires vs. Passenger Vehicle Tires
Special Trailer (ST) Tire Speed Ratings
Industry standards dictate tires with the ST designation are speed rated to 65 MPH (104 km/h) under normal inflation and load conditions.
However Goodyear Marathon and Power King Towmax STR tires featuring the ST size designation may be used at speeds between 66 and 75 mph (106 and 121 km/h) by increasing their cold inflation pressure by 10 psi (69 kPa) above the recommended pressure for the rated maximum load.
Do not exceed the wheel's maximum rated pressure. If the maximum pressure for the wheel prohibits the increase of air pressure, then maximum speed must be restricted to 65 mph (104 km/h).
The cold inflation pressure must not exceed 10 psi (69 kPa) beyond the inflation specified for the maximum load of the tire.
Increasing the inflation pressure by 10 psi (69 kPa) does not provide any additional load carrying capacity.
06-01-2016, 07:59 AM
Yes I knew all that, but the new Maxxis say and I quote " ST High Speed Rated" Parish Tire in Mayberry said that is new to this brand. Thanks anyway
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 09:35 AM
Always Learning
It's my understanding that recently there was a change to the rules surrounding the ST speed designation - it increased from 65mph.
My *guess* is that these "ST High Speed Rated" tires are the newer variety. However, I thought that they had to actually be stamped with an increased speed rating- not just "called" something new.
Have you contacted Maxxis about it?
06-01-2016, 10:51 AM
Commercial Member
Yes for an ST tire to have higher than 65 mph rating the "Speed Symbol" letter must be molded on both sides of the tire. If a tire dealer doesn't know this then he really is just an "order taker" and might as well be working the counter at a fast food place.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
06-01-2016, 10:52 AM
Commercial Member
Yup but this only applies to GY and TowMax as they are the only companies to put that info in writing. Anything else is just hearsay.
06-01-2016, 11:15 AM
All ST tires regardless of brand still have to meet industry standards. All the other stuff is just hype to sell something as new when it is the same old stuff.
06-01-2016, 11:27 AM
Well there is a speed symbol molded if that's it on them according to what I found. IF they are rated "R" (not the R in the 75/R15) which Maxxis says is max speed 106 MPH. How could that be true? I have a call into the Georgia head quarters now to find out. Also it gives that rating for the tire on Amazon also. I guess I will find out, same tire I have but under info it gives the code for speed on Amazon. I let you know what Maxxis says.
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 11:31 AM
Why not just take pictures of all the writing on the sides so the uninformed masses know what you are talking about?
06-01-2016, 11:37 AM
We have had Maxxis ST 8008 on two different 5thwheels .The Heartland went two sets and traveled nationwide w/ NO BLOWOUTS. Our DD and family has 36 ' Keystone TT running Maxxis ST 8008 for three years so far w/ NO BLOWOUTS. Just the facts .
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
06-01-2016, 11:42 AM
You could just look up the tire on Amazon if your interested, and then look up Max's speed rating chart by letter. Can't be any plainer then that and the picture is much much better then I tried to take. Like I said It's the same tire and I have a call into maxxis don't see what hard to see about that it's pretty easy but I can't see Amazon putting false info on there site, without potential law suits. I will see what Maxxis says. There is a conflict on the Amazon site. The same question was asked under Amazon.
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 11:52 AM
Don't know the concern, you say you never tow over 65mph anyway.
06-01-2016, 12:01 PM
He knew that, but couldn't fine anywhere what the rating was in writing. He checked on the web and couldn't find the info. They had to travel and pick them up for me from Mayberry to Winston Salem, they didn't stock the high speed maxxis ST. We will see what the factory in Georgia says when they get back to me. They took very good care of me and was completely honest in there answer. He also said they where new. Interesting that Amazon is the only place that gives the code for speed rating...
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 01:47 PM
Maxxis Corporation just got back to me they said that they can only tell me that they are safe at any rated highway speed by law. They also said they do not rate the ST tire for speed rating. I asked about the Amazon speed rating of 106 MPH she said I do not know where Amazon is getting there tires, but Maxxis will say they are safe at any posted speed limit in the USA. They will not commit to any recommended speed limit. She said if the speed limit is 65 they are good if it is 75 they are still good. They just will not commit. She also said it's not required by law to produce a max speed for there tire. Still confused maybe Tireman9 can make sense of it. I thought that every DOT tire had to have max limit that you can travel at a constant speed. I guess not according to Maxxis Corporate office in Georgia.
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 02:07 PM
I think whoever called you should run for a political office with a answer like that Maybe Trumps running mate
06-01-2016, 02:55 PM
Ha, this is true, all they list legally is the load at the PSI each tire can handle. So you got me, Have another call into the factory not the consumer's line.
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 03:24 PM
I was curious, I knew my Maxxis tires had a higher speed rating I was fairly certain it was not "R".
There might be an industry standard, but does not say it cannot be exceeded.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
06-01-2016, 03:52 PM
That is were the conflict comes in now Amazon rated them as "R" for speed that says 106 mph on there chart, then when you go down farther it has a chart that will say 65 mph. as she said that is what they have to show by law. I would think that the tireman9 would be able to make a call and find this out for us. Now who would go 106 mph's with a trailer. The load cap. is still higher then those Marathons I took off. Every place I read they are the best trailer tire out there. Granted that's not saying much.... But with 3 broken belts in 3 1/2 years, never hit a curb or over loaded and kept at 65 PSI they shouldn't have broken the belts in 3 tires. I thought Marathons were good, but I guess you just have to be lucky... Also my weight per tire loaded is like 1740 lbs.
Coachmen M/H
Concord
2018 / 300 DSC
06-01-2016, 03:55 PM
Places in Montana, there is no upper speed limit..............
FROG AR-0019-242
06-01-2016, 04:15 PM
anything above 80 MPH is a waste for me...fast as the ole Dodge will go...
2017 Puma 297RLSS
