Old 11-11-2014, 06:54 PM   #1
Metal hot water tank plug?
Discovered today that my hot water plug is metal. Bought trailer brand new in
April. (Wildwood 27RKSS)Can not get it to budge. Going to have to get a socket
to try and get it off. Why in the world would Forest River put a metal plug there.
I will get a plastic one to replace it. Has anyone else run into this?
Twocolleens is offline   Reply With Quote
Old 11-11-2014, 06:59 PM   #2
davel1971's Avatar
What were you trying to take it off with? You really want to trust city water pressure to a cheap plastic plug? Maybe its a anode rod and not a plug in there now.
David & Lynn
Old 11-11-2014, 06:59 PM   #3
fonzie's Avatar
If it's a Suberban water heater then it is an anode rod. Need 1 1/16 inch six point socket to remove...good luck
Fonzie
Old 11-11-2014, 07:11 PM   #4
As said that is probably an Anode not just a plug.
PB Blaster around the outside will help once you have the correct size socket. (Recommend 1/2" drive)
For the winter I actually use a plastic plug with some Fluid Film sprayed on it to keep it from rusting up. Then put a new anode in with plumbers dope/tape in the spring.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 11-11-2014, 07:17 PM   #5
wmtire's Avatar
As others have stated, it's most likely the sacrificial anode rod, which you do remove to drain the Suburban water heater. You will need to keep an anode rod in this type of water heater as it helps preserve it.
You will also need to replace the anode rod as part of routine maintenance.
Here is some youtube videos:
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-11-2014, 08:24 PM   #6
2011 Forest River Stealth
rwtdct's Avatar
It is suppose to be metal with a anode rod behind it. If you are going to take it out for a reason (other than to replace it with plastic) use a 1/2" drive with a 1 1/16 socket. Before you take it out make sure there is no pressure behind it. (turn on facets to relieve pressure).
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 11-11-2014, 08:27 PM   #7
davel1971's Avatar
there is a relief valve right above it
David & Lynn
Old 11-11-2014, 08:50 PM   #8
rwtdct's Avatar
You can use this too. don"t get wet.
Also make sure the water in the tank is not hot.
2011 Polaris RZR 4
Old 11-11-2014, 08:56 PM   #9
B and B's Avatar
I had to use a Impact wrench to get my Anode Rod out the first time. The rachet motion loosened the plug.
I have a Atwood in my Park Model and it is a plastic plug and doesn't leak or has blown out in 7 years.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-12-2014, 06:23 AM   #10
Thanks everyone for your help. I will tackle this project real soon.
Just have to get the proper tools.
hot water, tank, water, water tank
