Mice problems....Who Me?
being a farmer and storing farm reactors in the barn all winter, rodents can and will be an issue. Mice like cozy spots like under cushions and in air cleaners...
I learned a good trick (besides having a barn cat or 2) and that is, remove all the food stuffs (which helps) but the sure cure is dryer sheets placed in, in my case, tractor cabs and under hoods, in your case, in the RV in various spots, make sure it's buttoned up tight too.
I keep mine (RV) in the equipment barn with the tractors and it had a few dryer sheets inside too.
Cats are good, but not foolproof and cats have a bad habit of whizzing on things, so they don't work in an RV unless you want your RV to smell like cat pee....I don't.
