Old 09-25-2013, 09:52 PM   #1
Mice Already
I can't believe it...I've only taken the TT out once and took virtually no food. I set traps once home and didn't even bait them because I didn't want to attract mice. There was a mouse in one of the traps. I feel sick...
2014 Rockwood 2304S
2011 Nissan Titan
jtintx is offline   Reply With Quote
Old 09-25-2013, 10:10 PM   #2
aka Windjammer2012
Crankshaft's Avatar
Yep! Looking for a warm spot for the winter. Go to Lowes or HD a get a can of sealant foam. Go through your trailer from the interior and exterior looking for gaps especially where wires and propane lines enter the trailer. Foam the gaps real good but take into consideration that the foam really expands within a minute or less. Then set your traps to get the last of the varmits.
Wayne & Vonnie
Layla (American Eskimo dog)
2012 Windjammer 3008W
2004 GMC 2500 HD CC Longbed
Crankshaft is offline   Reply With Quote
Old 09-25-2013, 10:58 PM   #3
Love My Sunseeker
DXSMac's Avatar
Or get a cat! My cat was good at catching them!
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 09-26-2013, 05:42 AM   #4
EastlakeRoo's Avatar
Yah, I have been thinking about the mice issue as well. Our trailer is stationary and while we haven't had any problems nor seen any issues with mice several neighbors have been having issues with mice getting into their trailers over winter.
There are so many remedies available online from bounce (regular scent) dryer sheets to electronic controlled devices you plug in that is suppose to discourage them from getting in but I'm not sure if there is a 100% proven method to rid them.
What I did already
* already went around outside of trailer filling in gaps with spray foam.
* have 3 electronic mice devices plugged into outlets throughout the trailer.
These are on all the time now but when winter comes they will be off as
electric will be shut off.
What I'm planning to do:
* eliminate all food within trailer.
* try the bounce dryer sheets method. Will buy a box and place throughout various
corners of trailer.
* once trailer cover is on, will put a few moth balls under outside side skirts of trailer
hoping the smell will discourage them.
Will use regular scent on outside and cedar smell on inside. (Drug Mart has these)
I have read that Pepermint Oil 100% works on cottom balls but the price is very
expensive so I guess we will try what I mentioned above to see how it goes.
Hopefully no issues.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 09-26-2013, 06:17 AM   #5
KyDan's Avatar
Good luck everyone!
Mice are a problem for lots of folks not just RVers.
Some thoughts from an old guy.... me!
It's not always about food. Sometimes they just want a nice dry "safe"
place to build a nest. They can go out for food! Example- I've found
mouse nests in my lawn mower. No food there. Also found nests in a
outdoor shed with power equipment hand tools, shovels etc no food there.
If you don't worry about cats or kids you can put mouse poison trays
around outside under your trailer. This will usually take them out before they
go in.
We had issues with mice getting in our home every fall- about this
time of year. We have a covered deck in back and I suspected they
were getting in somehow under there. I now place poison under the deck
all year and renew it in the fall. No mice in the house the last 5 years.
I found one entry where mice had chewed a hole in vinyl siding and
then chewed thru 3/4 foam board and got in. I stuffed that hole with
steel wool. They don't like to chew steel wool.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 09-26-2013, 07:42 AM   #6
Rad
Rad's Avatar
Originally Posted by KyDan View Post
Good luck everyone!
Good luck!
FYI -- steel wool is quite flammable and can be dangerous as a hole plug! Steel wool has even been known to spontaneously combust.
So be careful!
"During the production of steel wool, a slicing tool shaves fine threads of metal, which produces a tremendous amount of heat. To reduce the chance of fire and lessen friction, the slicing tool is kept cool with oil, but this means the steel wool itself contains some oil, which makes it highly flammable and likely to spontaneously combust later on.
Keep steel wool away from open flames and any kind of electrical or mechanical spark -- unless you want to start a fire. You might consider bringing steel wool on a camping trip because you can use it to start a fire even if it's wet. Simply hold one part of the steel wool to the positive end of a battery and another part to the negative end. Rubbing the two terminals of a 9-volt battery against the steel wool works well too. Just don't keep the battery and the steel wool together in your pocket or pack or they could start a fire on their own!".
Rad is offline   Reply With Quote
Old 09-26-2013, 08:14 AM   #7
Lynkage's Avatar
No matter what, there will be water close by. That is the primary reason they build where they do.
Take away the water source and they will leave. Not typically an easy thing to do.
Other than that, what the others have said is good practice. Clean is best.
Good Luck!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 09-26-2013, 08:16 AM   #8
KyDan's Avatar
Wow! I know what you're talking about : oxidation creating heat but....
I have been using steel wool to finish sand various wood varnishes for
40 years. It's comes in little "bales" wrapped in card board.
Never have I seen one with a caution on it..... it's also definitely -not- oily.
If they're using oil in the manufacturing process they are degreasing it B 4
packaging.
You could go buy a copper scrubbie and stuff that in a mouse hole.
They probably wouldn't chew that either.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-26-2013, 08:37 AM   #9
Arefbee's Avatar
Tried putting chunks of Irish Spring in every possible concealment area last year and had no issues after. Also used an ultrasonic device but the thing to remember there is it does not work through walls so they can still be inside crawl spaces.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 09-26-2013, 08:45 AM   #10
mjones12's Avatar
Good luck everyone!
go in.
Good luck!
You are right. They will build almost anywhere. I once found that mice had built a nest in a manual typewriter. They pulled out the ribbon into a ball and added some chewed-up paper to that. One mouse was still in there when I discovered it. This was in a cabin at a summer camp where I was employed many years ago.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
