Originally Posted by mgmoses
Hi all -
I have the 2014 Micro Lite 21 ft. I can't seem to find the source of leak into the storage compartment on the same side as the slide out. Anyone else have a problem with Micro Lites leaking? Any help with the solution would be appreciated!
Water pump? City water check valve, Filter housing/fittings? Water heater bypass valves.
Does it leak when on City Water or when using pump.
Sometimes you just have to run your hand along every water line until you find "wet".
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
