Old 08-15-2016, 10:30 AM   #21
JustB_Rad's Avatar
Originally Posted by aceinspp View Post
Where can you buy the wet and forget product? Later RJD
I found it cheapest at Menards...it was back towards their paint section. I believe Lowes and Home Depot also carry it.
https://www.menards.com/main/back-to...4446512287.htm
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
Winter :'(
JustB_Rad is offline   Reply With Quote
Old 08-15-2016, 10:39 AM   #22
You may want to check if there is a leak in your awning. We don't use the awning a ton, but when we would open it, it would always be wet, and we were having mildew issues. We are parked level when we aren't using it, so we couldn't figure it out. Then one day we have the awning extended and it started to rain. And there was a drip that appeared just above the door. Where the awning attaches to the rv, there was a spot where water was getting through. So that was the issue, when it was rolled up in storage, every time it rained it would let water in and you know the rest, mildew. So I would check that out. Otherwise, I have found a spray at Walmart, for awnings, and it is some combo of vinegar and other stuff. It smells like vinegar anyway. You spray it and give it a scrub, and it comes right off. Then you spray it again and let it dry, and it is supposed to prevent. We haven't had an issue since. Off the top of my head I don't remember what its called, but it was in a white spray bottle (similar in size and shape to Windex)
_________________________
2015 Rockwood Mini Lite 2504S
2015 Ford F150 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 08-15-2016, 10:59 AM   #23
My local Lowe's sells it. (Paint section)
I've also bought it on Amazon.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-15-2016, 11:03 AM   #24
I've posted this before... I have a lot of luck using JOMAX on my awnings.
Seems to keep the mold away for a good while.
I recently used Wet & Forget on my garage roof and I'm impressed with the results.
Not sure how it will do on the awnings but I'm willing to try it based uopn the garage roof.
Old 08-15-2016, 11:07 AM   #25
Wolverine 1945's Avatar
I Goggled it,,, and saw that Ace Hardware showed a better price than HD ???
Wolverine 1945 is offline   Reply With Quote
Old 08-15-2016, 11:10 AM   #26
JustB_Rad's Avatar
Beware, I don't think it will "Clean" as well due to your awning being rolled up, however, it should still be a good prevention for mold and mildew.
Winter :'(
Old 08-15-2016, 11:20 AM   #27
Yep, roger that.
I should have been a little more clear.
I actually meant, spraying on after the awning is cleaned (and letting dry) to prevent mold/mildew.
The Wet & Forget is designed to 'stick around' after spraying to clean gradually during each rainfall or similar. The instructions say something like.. it could take several months to see results. That was the case with my garage roof but it has kept the mold off too which is why I thought about trying it on the awning.
Thanks!
Old 08-15-2016, 11:27 AM   #28
JustB_Rad's Avatar
Yep, roger that.
Thanks!
Winter :'(
Old 08-15-2016, 11:33 AM   #29
Georgia Frog Rally 2017
aceinspp's Avatar
Thanks Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-17-2016, 12:34 AM   #30
Capsfloyd's Avatar
Awning
Use Awesome. Sold at dollar stores works great.
Capsfloyd is offline   Reply With Quote
awning
