08-15-2016, 09:30 AM
#21
Originally Posted by aceinspp
Where can you buy the wet and forget product? Later RJD
I found it cheapest at Menards...it was back towards their paint section. I believe Lowes and Home Depot also carry it.
https://www.menards.com/main/back-to...4446512287.htm
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
08-15-2016, 09:39 AM
#22
You may want to check if there is a leak in your awning. We don't use the awning a ton, but when we would open it, it would always be wet, and we were having mildew issues. We are parked level when we aren't using it, so we couldn't figure it out. Then one day we have the awning extended and it started to rain. And there was a drip that appeared just above the door. Where the awning attaches to the rv, there was a spot where water was getting through. So that was the issue, when it was rolled up in storage, every time it rained it would let water in and you know the rest, mildew. So I would check that out. Otherwise, I have found a spray at Walmart, for awnings, and it is some combo of vinegar and other stuff. It smells like vinegar anyway. You spray it and give it a scrub, and it comes right off. Then you spray it again and let it dry, and it is supposed to prevent. We haven't had an issue since. Off the top of my head I don't remember what its called, but it was in a white spray bottle (similar in size and shape to Windex)
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
08-15-2016, 09:59 AM
#23
My local Lowe's sells it. (Paint section)
I've also bought it on Amazon.
08-15-2016, 10:03 AM
#24
I've posted this before... I have a lot of luck using JOMAX on my awnings.
Seems to keep the mold away for a good while.
I recently used Wet & Forget on my garage roof and I'm impressed with the results.
Not sure how it will do on the awnings but I'm willing to try it based uopn the garage roof.
08-15-2016, 10:07 AM
#25
I Goggled it,,, and saw that Ace Hardware showed a better price than HD ???
08-15-2016, 10:10 AM
#26
Beware, I don't think it will "Clean" as well due to your awning being rolled up, however, it should still be a good prevention for mold and mildew.
08-15-2016, 10:20 AM
#27
Yep, roger that.
I should have been a little more clear.
I actually meant, spraying on after the awning is cleaned (and letting dry) to prevent mold/mildew.
The Wet & Forget is designed to 'stick around' after spraying to clean gradually during each rainfall or similar. The instructions say something like.. it could take several months to see results. That was the case with my garage roof but it has kept the mold off too which is why I thought about trying it on the awning.
Thanks!
08-15-2016, 10:27 AM
#28
Yep, roger that.
Thanks!
08-15-2016, 10:33 AM
#29
Georgia Rally Coordinator
Thanks Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-16-2016, 11:34 PM
#30
Awning
Use Awesome. Sold at dollar stores works great.
08-17-2016, 04:52 AM
#31
^^this. Used Awesome on mine a few weeks ago. It came out, well, awesome.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
08-17-2016, 09:08 AM
#32
I've used Super Clean by Castrol and always have good results. Works great on black streaking and bugs. High concentrate degreaser and cleaner sold at Wal Mart etc. and auto parts stores in a purple gallon jug in the automotive section. I have used this on laundry stains that won't come out with Oxy Clean or other laundry stain products. Spray on the stain and let it sit a day or two and the stain washes right out. I have used Awesome around the house too. Works great as a carpet spot cleaner or pet stains. BIL uses it on his trailer to remove black streaks. Always have a bottle under the sink.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
08-18-2016, 02:08 PM
#33
Magic Eraser took mine right off.
08-18-2016, 05:08 PM
#34
Awning mildew
I use Wet and Forget. Bought it at either Lowes or Menards? Have had very good results with it on both my awning and on my Dacron covered airplane. Follow the instructions provided on the label.
08-19-2016, 06:32 AM
#35
And the wax also hey ???
I used a Magic Eraser on a skid mark on a indoor house door one time,,,
It not only removed the skid mark but some paint also !!!
08-20-2016, 08:20 PM
#36
Wet and forget it where do you buy it
08-20-2016, 08:29 PM
#37
Our local Lowe's has it in the paint department.
Amazon has it too.
08-21-2016, 09:16 PM
#38
Magic Eraser
I tried Kaboom and it worked some but it was a lot of scrubbing. On a whim, I tried my tried and true Magic Eraser and it was so much easier. Be sure to rinse the eraser very few feet and have a rag to wipe away residue. It isn't perfect but it looks so much better
08-22-2016, 05:38 AM
#39
WOW,,, you cleaned your entire awning with a Magic Eraser !!!
08-22-2016, 06:14 AM
#40
Super Clean by Castrol, true story. Was going to clean some blinds. Hung blinds up outside on dive way supported by wood strip on ladders. Sprayed with Super Clean in pump up. Sprayed with hose they came out all bright and shiny. All the paint came off leaving just aluminum. Bought new blinds. Don't get that stuff on your hands. But is is a great cleaner. Dilute as directed.
2013 Flagstaff 831FKBSS
