Old 03-14-2015, 09:43 AM   #1
2015 2503S Mini Lite
Saberwolf 700's Avatar
Mirror extender's Needed?
Newbie here with my first post. Woo Hoo!!! OK, got that out of the way.
Anyway more to the point here, we just bought a new 2015 2503s Mini-Lite this past fall. At the time I purchased my TV was a 2008 F150 and I noticed that I might like mirror extenders on it.
Well since then I purchased a 2014 Ram 1500 Big Horn and it just looks wider than the F150. My question is does anyone have experience with this setup and do you need the extenders. I would rather not having to use them but don't want to find out too late that I need them.
Saberwolf 700 is offline   Reply With Quote
Old 03-14-2015, 10:47 AM   #2
Chevy Two's Avatar
You will need to see what is going on around you ALL the time! It's not your ability to drive it's all the other idiots out there. You will have a lot going on changing lanes,passing an getting passed,turning,backing up you name-it you'll want to know what is happening. CW has several types of mirrors you can get if you don't like them you can always take them back.
Get a pair for everyone's safety.
Sent from outer space! 🇺🇸😄😄🇺🇸
Chevy Two is offline   Reply With Quote
Old 03-14-2015, 10:59 AM   #3
factory tow mirrows are available but double check your mirrors first they might pull out for towing.
uhduh camping is offline   Reply With Quote
Old 03-14-2015, 11:51 AM   #4
I've checked the mirrors, not the pull out type. Guess I could hook it up and do a test drive around the area. Might be an option once I get it uncovered.
Old 03-14-2015, 03:24 PM   #5
wbdavey's Avatar
Saber - I pull a similar trailer (Rockwood 2604WS) with a '14 Ram that does not have factory towing mirrors. I purchased a set of clamp on mirrors (they're 1500 miles away right now). I found that the driver's side clamp on is a tremendous help in seeing what's behind the trailer as you travel. The passenger's side is less helpful because the Ram mirror is convex and shows nearly as much as the clamp on. Just my experience.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 03-14-2015, 09:25 PM   #6
gashog's Avatar
On my 2014 Ram the mirrors do not pull out, but rotate like this youtube video demonstrates.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 03-15-2015, 06:17 AM   #7
searay245se's Avatar
I have a 13 Ram and bought the extenders that go right over the stock mirrors and they work great and are a lot cheaper then buying the factory tow mirrors and then having the computer flashed by the dealer so they work right.
Jeff & Debbie
2015 Tracer Air 255
2015 Ram Laramie Power Wagon 2500
searay245se is offline   Reply With Quote
Old 03-15-2015, 11:05 AM   #8
Thank you Ram owners, these are the answers I was looking for. Now I can start looking for the mirror extender's that will work best for me. Let's camp!
Old 03-15-2015, 12:14 PM   #9
Mirror extenders- these are great. Go to Traliler.com . The slide on mirror made for y
Go to etrailer.com . Slide on mirror extenders are great and made for your specific truck. Traveled from WV to Wisconsin on to So. Dakota and back to WV. No vibrations good views down sides of RV. Under $80.00 for both sides.
Mr. Mike 45 is offline   Reply With Quote
Old 03-15-2015, 12:46 PM   #10
SkipBest's Avatar
Mirror help
I second the eTrailer suggestion. Great service and good advice via phone.
Skip
SkipBest is offline   Reply With Quote
